Old 08-31-2008, 08:03 AM
ctcown ctcown is offline
97 geo metro stopped running
Hi! Guys got a ques. for ya I was driving down the road the other day and the geo just stopped running like you cut the key switch off. The car was running perfect no problems what so ever before this happened. towed the car home and check for fire to the plugs and it has it, checked to see if the fuel pump was working and it is. you can pour gas in the tbi and it will run for a min. so I know the problem is a fuel issue but I don't know if its the injector or ecm or some other senser. The injector is not pulsing or spraying fuel.
Any idea's would be great
Old 08-31-2008, 01:46 PM
doug2060 doug2060 is offline
Re: 97 geo metro stopped running
You will have to troubleshoot this issue but it is easy. Be sure you have plenty of fuel in the car. Do you hear the pump build pressure when you turn the ignition on? If not you may have a bad fuel pump which is common but be sure to check your relay first to be sure it is clicking on also check any related fuses. If all that checks out be sure you are getting fuel pressure to the injector. You could have a clogged filter but it's usually not the case in my experience. If you do have proper fuel pressure on the line at the injector and fuel is not being ejected from the injector you could have a faulty injector but be sure to check it's relay and any related fuses. Good luck...
Also: Is the check engine light on when you crank it with starting fluid? You may want to scan it for other issues.
Old 08-31-2008, 04:05 PM
I have a half tank of fuel with 25 psi at the tbi unit when you pour gas in tbi it runs smooth like it always has and yes the service engine light is on
Old 08-31-2008, 04:13 PM
Scan it to find out what is causing it to come on and it may lead you to your problem.
Old 09-01-2008, 05:35 AM
Woodie83's Avatar
Woodie83 Woodie83 is offline
SES light should tell you the problem or at least give you a good clue. I'm betting crankshaft or cam position sensor.
Woodie
98 Metro and 06 Aerio SX
Don't waste your vote on one or the other of the Republicrats, vote for Gary Johnson and really do something for a change
http://www.garyjohnson2012.com
Old 09-01-2008, 06:34 AM
gob 455 gob 455 is offline
If you have fuel pressure, and it runs when you prime the TBI unit, I would check for power at the injector with a noide light. If you have a chain store parts store (Checker, AutoZone, O'Rilies, Pep Boys) they will usualy loan you special tools. You have to pay for them but, you get your money back when you take the tool back. To test, you'll need to find the wires that go to the injector and unplug them. Plug the noide light into the wireharness and crank the engine over. The light should flash. If it dosen't, dubble check your fuses, power conections and grounds. If this all checks good it could have a bad compuetor, but it I would be suprised if this was the case. Get a Haynes manual for good wiring diagrams.
Old 09-03-2008, 06:30 AM
The niode light is not flashing when you plug it in the wiring harness and spin the engine over plus the pcm is not throwing any codes
Old 09-03-2008, 07:13 AM
Have you checked your throttle position sensor?
Old 09-03-2008, 09:59 PM
RossT RossT is offline
I know this doesn't fit your symptoms, but it takes just a minute to check to make sure your timing belt has not snapped.....
Anytime someone says there car just died, I always fuel, spark and timing belt first.
Old 09-03-2008, 10:28 PM
If it runs when he pours gas in the intake the timing belt is intact.
Old 09-04-2008, 01:37 AM
Yes that is a true statement, that's why I stated that it doesn't fit his symptoms. But sometimes the belt will slip a tooth or two or partially shred.
It's an easy check, and it will rule out one of the more fequent cuases of a car just dying.
I remember one guy on this forum that had the teeth part of the belt shred off, thus the belt would slip and barely run. It took him awhile to diagnose it cause he still had fuel and spark..
anyway, it's just a thought and would be on my checklist
Old 09-04-2008, 01:49 AM
True, it is always worth checking but if no fuel is coming out of the injector at all and it will start and run when giving it a few squirts of gas the timing belt can be reasonably ruled out.
Old 09-04-2008, 03:01 AM
Good point!
Hope your not at work like me.
Old 09-04-2008, 10:34 PM
Hi guys I got a scaning tool today and pluged it into the car and it is not throwing any codes would the tps sensor not let the car run without throwing a code and what does the car do if the pcm is bad. Plus the car has a distributor where would the cam sensor be if it had one I thought car's that did not have a distributor were the one's with a cam sensor. This thing is kicking my butt and I know its something simple I'am just lost when it comes to the newer car's a carb would be nice. I sure do miss the money i save in gas with this car
Old 09-04-2008, 11:41 PM
Yeah, The TPS should throw a code. I don't think there is a cam position sensor. I'm not sure about your 97 but my 98 has the crankshaft position sensor located directly under the timing pulley on the passenger side of the oil pan. Here is a pic that may help you locate it.
