Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 08-31-2008, 05:58 AM
jujl62 jujl62 is offline
Unhappy 2002 Dodge intrepid Problem
We have a 2002 Dodge Intrepid and have replaced the input and out put sensors. But when we took it out today for a test drive still having problems. We will feel a chug and than the RPM will go up,if we pull over and shut the car off it will reset it. I had a test ran and came up the code P0700. Is there anything else we can do
Old 08-31-2008, 08:11 PM
tempfixit tempfixit is offline
Re: 2002 Dodge intrepid Problem
Code P0700 means Check Transmission DTC's. Read this thread it should help you, it propably the solenoid in the tranny sticking.
http://www.automotiveforums.com/vbul...d.php?t=914698
When was the last time the tranny fluid and filter was changed?
Which engine? and how many miles on vehicle.
Old 10-19-2008, 03:34 PM
sweetpea50009 sweetpea50009 is offline
I have the same car and I can only pull the P0700 code. I took it to get codes from it and it spit out one other code. (can't remember code) It was for a solenoid replacement. I am having it fixed tomorrow and that should be the end of it I hope. (by the way, i am selling mine as it will have more probs later....suggest the same.)
