Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 08-30-2008, 09:55 PM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
Cooling And Knock
Hey guys, ok so i have 2 problems.
one, i have a problem keeping the engine temp down. engine is rebuilt w/ forged internals, and stage 4 turbo kit, all done pro, and has a tune, i run about 22 psi.
oh and its a 97 eclipse gs
its fine, and this isnt a HUGE problem but, if i still still at idle for a long period of time...maybe few mins...the needle for the engine temp gauge begins to rise..., and when i take off itll go back down to normal of coarse. but how can i further reduce the engine temp..? are there any methods of doing this for street tuning? i have a racing radiator...and like i said its not a huge problem, but id still like to address it.
and two, ive noticed a knock when under load(or accelerating in a turn) and when the engines cold...a little...once the engines warmed up it doenst do it much, unless like i said i boost it hard in a turn...is this fixable? or do i just have to live with it..?
Old 08-31-2008, 11:18 PM
vzfox vzfox is offline
Re: Cooling And Knock
You have two elect. radiator fans.....do they both work like they should?
Old 09-01-2008, 09:32 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
You need 2 fans running nearly constantly for something like this. Hell with my little t3/4 setup on the ESi, it would start to over heat with 1 10" fan. Now have a 10" and a 12". You might what to consider wiring them up to either be on all the time or to a switch where you can control via inside the car to turn on/off.
I'm going to guess that you're using a rather large FMIC too then right? You may want to make a little air dam under the car to scoop the air around the FMIC to the radiator. And is your A/C still in? If it is, and you don't use it at all, rip the core out and that will lower temps quite a bit.
May also want to get some aftermarket coolant, like Redline Water or whatever they call it. Usually running that with a slight water mix will lower temps a couple degrees.
The knock sounds like it's a suspension issue. Check all the ball joints and pull on them for looseness and movement. Also try wiggling the tire when it's raised up to check for movement. Lastly, try compressing the shocks and see if they pop when doing that. Does it come from a specific side? Was the lower control arm recall done to the car at any point?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 09-03-2008, 08:19 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Is the knock coming from the motor?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 09-05-2008, 06:59 AM
Talking Re: Cooling And Knock
The knock is def. coming from the engine...for those of you who really care to help a fellow tuner in need, heres a short story.
So I was trying to drive down a path(not gravel or highway) and heard what sounded like my underdside scraping the ground a little, but then I got back onto the road, and drove about 15 mins b4 I realized my oil light was on, and I pretty much knew why...I was right, my oil filter had hit the ground and gotten damaged, I leaked oil fast, but almost as soon as the light came on and I realized my engine temp was rising fast I obviously shut the engine off immediately, and pulled over, fixed it after a few phonecalls, and it was just the filter that was damaged.
Now, the car runs like a sewing machine, never fails, REALLY great condition for a 97'. But, could that have had anything to do with it knocking only sometimes?
Here is when I hear it knock:
1)when engines cold
2)if i slowly iron out 1st gr or hol dthe accelerator steady in this gear
3)if i put the accelrator down while turning left I can hear it start to do it...
what is the problem haha...please help me there, its my biggest concern
And I actually have a side mount intercooler, so the radiator gets plenty of air, and I was going to go today to a body shop and see if i could have a vent cut out of the side of my front bumper to have air hitting the ic a little bit better, and a little for looks of coarse
I have a c&r racing radiator with one fan...guess I should upgrade to two fans...also I plan to get a carbon fiber hood, to relieve some under hood temp. this will help a little correct?
Also, do you know anything about the oil coolers, and would this be a good buy for me? For my problem...
One more question. I have JE pistons, total seal rings, crower rods, and im able to run 22 psi on my tune, more if i upgrade the injectors. It made 320hp at the dyno when it was tuned. I was thinking of upping the boost a little, and was curious as to whether or not any of you know from experience, and based on my setup, how much more my engine(now) can hold, and what I would have to do next to further strengthen it(in other words, the next step for me). A buddy of mine who owns an evo tried running around 20 psi on his evo w/ a boost controller, only a few psi over stock, and blew the engine. He claims he doesn't understand how im able to run so much boost on this engine...could someone inform me correctly of its potentials? Are these engines weak? Should I be extra cautious for any particular reason? I had a civic, got an eclipse, and am new to dsm...sorry..=/ But these are questions I cant seem to get answered elsewhere.
I apologize if my questions sound retorical, But im obesessive compulsive and ALWAYS have to ask and doublecheck myself...so that im sure what im doing is right. Also, sorry so long........
Thanks!
Old 09-05-2008, 07:05 AM
Also, for further reference, here is my setup
HahnRaceCraft Stage IV super 16g turbo w/ side mount intercooler - Hahn turbo manifold - 240cc injectors - Hahn Portfueler system w/ intake spacer, secondary fuel rail w/ 400cc injectors - 1:1 aeromotive fuel pressure regulator - fully programmable fuel controller(pretuned) - walbro 255lph fuel pump - Hahn fuel mapper - 3000gt bov - JE pistons(8.6:1) - Total Seal piston rings - Eagle rods - AEM synthetic filter - C & R racing radiator w/ high flow fan - Hahn 3'' downpipe & cat - THermal Engineering 3'' cat-back - Clutchmasters stage IV clutch - Eibach sportline progressive lowering springs - Front Eibach offset bushings(camber adustment) - KYB GR2 struts - Front & rear strut bars - Lower rear tie bar - GReddy profec type s boost controller - autometer boost & electronic fuel pressure gauges - Apexi universal turbo timer - Pioneer mp3 head unit & speakers - odyssey PC680 battery - Front Powerslot drilled & slotted rotors
Again, all help is very appreciated!
Old 09-05-2008, 01:53 PM
Holset powered 420a
The oil light comes on when your oil pressure goes less than 5psi I believe. So Im better your damaged the motor. I would drain the oil and look for metal, also you may want to pull the oil pan and check your bearings.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-05-2008, 06:15 PM
Ok, so no metal in the oil pan, im guessing i was supposed to look for little flakey pieces of metal correct?
Well either way, all is quiet on that front.
And id like to add, i didnt mean to make it look obvious that thats my problem with the motor, the whole oil thing, bc somehow or anohter i just dont think that did any real damage, bc the thing runs like a sewing machine...i mean it couldnt be better...EXCEPT the few rare times when it does knock...and im wondering if its too small of a problem to be worried about...
I was planning in the future to strengthen the motor even more, but had several questions.
If I plan on running nitrous oxide, what further modifications would you recommend I invest in, based on my setup now, and keep in mind im already running 22 psi which I keep hearing is already way too much for my motor as it is? can someone clarify? Well, I was htinking, if i work on the head, it would be a good opportunity to go ahead and try and diagnose the knock...but ill cross that bridge when i get there...
As for the heating issue, I believe im gonna try some high temp coolant(bc mine disapeers almost as soon as i put it in the resevoir. Also im gonna order a carbon fiber hood to vent the heat a little....also, i do have only one fan on my radiator...on the right side of it, guess it wouldnt hurt to put another one on there...
anyways, hey thanks man for helping me out, and further help is greatly appreciated!
Old 09-06-2008, 12:59 AM
david-b's Avatar
Dave is THAT guy
Couple things...
With the setup you have right now it should be able to hold quite a bit of power... depending on how everything was assembled. 22psi is a lot, but if it was built with care and experience, it should be fine. Don't worry about the head... stock is fine. Maybe some port work but it's really not necessary. Most stock heads flow too well to begin with.
So your coolant is disappearing and you're having overheating problems eh? Where is the coolant going? Sounds your head gasket may be shot or going and coolant is leaking into the motor. That will need to be taken care of first. Do a compression test too and post up some numbers. When you drained the oil, was there any coolant mixed in with it?
Vented hoods reduce the ambient temps under the hood. Always a plus.
Lastly, could I see a dyno graph?
75 Monte Carlo
Old 09-06-2008, 10:59 AM
Holset powered 420a
Your motor is built to take a lot of power. Your pistons/rod combo should take over 500hp. So 22psi is alot but as long as your not knockin you will be fine. What do you need nitrous for? You already have no traction.
If the knock isin't that bad then ignore it untill it gets worse or something fails. The only problem is that other damage may occur. As far as coolant goes, do you have any leaks? The car would smoke if your burning coolant.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 09-07-2008, 04:37 AM
Thats all good to know, and thank you so much. It makes me feel a lot better to know I can handle much more than ive got.
Umm, heres the thing, I built a civic up myself, in automotive school, and when I sold that I bought the eclipse, most of the work already done. I dont have the dyno results, but the previous owner may, ill look and post it if i can. But I have no doubts, it runs like a scaulded dog, and I took it to a local track and walked away from an evo w/ a few mods. The previous owner I know and trust, who also owns an evo(much more powerful one) He built up my eclipse, and did the work himself, so the work was done pro. I was just inquiring from different sources as to what my best bet is to do next...performance wise. I'd like to know what everyone else in my shoes would do next, you all now knowing what I have.
Lets see, no there was no coolant in the oil or oil pan, no metal, and it doesnt burn coolant either. No leaks anywhere on the car, everything is in pristine order. I think ill take yous' guys advice and get another fan(the radiator I ahve only has one on the right side) and a carbon fiber hood.
I do have a question based one what you just said, about my head being as strong as I need it to be for now, but would it be wise to go ahead and at least get some stronger head bolts? Just seems to me like the bottom is ready to rock, but the head hasnt been modded at all, but if you say its good to go, ill take your word for it.
Do I need to try and seek any more boost? Should I leave it alone? If I were to want a good even 25 psi, based on my setup, do i need to strengthen anything else? Maybe a stronger head gasket? Bc all i need to do to up the boost now is get larger injectors...so i wanna make sure im ok b4 i do it.
My ultimate goal for this car is around 500 all said and done. I am planning fixing the grinding third gear sync., and when I do, im adding a flywheel(btw anyone suggest a particular flywheel make??). So that should free up some hp for me.
Lastly, as far as the nitrous, its one of those things I dont HAVE to have of coarse, but id like to someday, and I was just curious as to why you think I already dont have any good traction? Or whats your reasoning for suggesting so, and what can I do to improve...
It goes without saying, I appreciate all your time here, I HATE having to ask people these things, bc it seems as though once you buy into a little power you automatically become a dick around here.
Old 09-07-2008, 05:41 AM
Oh and one more thing, I didnt wanna start a whole new post for this, but I was interested in buying a set of pulleys, never bought them for an eclipse b4...have a few questions.
1)Which set is best for the eclipse?
2)Its not particularly aggrivating to install on the eclipse is it?
3)Is there anything special I have to do to install...the reason I ask is bc I bought a pulley for my honda I had and couldnt have it installed bc there was a small part cut out from the inside of the inner hole that made it so it had to have a special little bitty piece of metal or else it would be secured, A "keyway," and I had to have it special made at a machine shop, a little cube shaped piece of metal about the size of a pea...haha it was kind of aggrivating, this is why I ask.
Old 09-07-2008, 02:32 PM
david-b's Avatar
Dave is THAT guy
There's only UDP for the 420a motor. Concept Illusion was making a complete pulley set for the past couple years but I don't think that'll ever get done. Cranks pulleys are basically just pop off and put the new one on. I didn't even use a crank pulley puller.
75 Monte Carlo
Old 09-07-2008, 04:57 PM
Nice...any idea how much horsepower thatll free up for me? Bc im probably about to order one here in a few, as soon as i hear back, that and a 10 inch fan lol
So that answers that...and as for the other questions...?
Thanks a lot!
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 09-07-2008, 06:16 PM
david-b's Avatar
Dave is THAT guy
Thanks a lot!
UDPs usually free up about 10whp they say. How true is that I don't know.
75 Monte Carlo
