Old 08-30-2008, 06:48 PM
Jason/RKBA's Avatar
Jason/RKBA Jason/RKBA is offline
Water pump
Mine has started the death squeak so I will be changing it very soon. It looks pretty easy and straight forward, does anyone whom has changed one on the 2.2 ohv no of anything I should be aware of before getting started?
Old 08-31-2008, 04:03 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
Re: Water pump
when i did mine i removed the alternator and reservoir for extra room, both of those are very easy to remove. it made the job very simple
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Re: Water pump
well this FUCKING website never lets me edit my posts, but i wanted to add that it is the coolant reservoir i was talking about
Old 09-14-2008, 11:47 AM
crankgrinder crankgrinder is offline
Re: Water pump
If you have already changed the pump, good for you. These 2.2s can be a real pain to change stuff on. I havent had to change a pump but i have replaced the tensioner, idler and belt and it helped me in a big way to put a jack under the rear of the engine with a phone book between the jack and the motor itself and disconnect the coolant bottle, and the front motor mount and jack the motor up a bit. It gave me so much more room and made the job so much easier. Thus far no leaks or knocks or wierd stuff like that has resulted from it.
Old 09-14-2008, 01:10 PM
Jason/RKBA's Avatar
Re: Water pump
I changed it out yesterday. I just removed the reservoir it wasn't the worst one I've ever done but everyone's ideas made a lot of since once I got started. I also changed the T-stat while I was at it. The water outlet's lower bolt was a real pain I had to use a very long ratchet extension and go behind the exhaust manifold (took it off only to replace the gasket this is not a necessity to change the T-stat on the 97 2.2 OHV). She is running cool as can be now. One tip I have is when your ready to fill it back up with coolant fill the reservoir than let it set for a few minutes for the air to find its way out and top off again, I did this about four or five times before the level stopped dropping. Sounds obvious but I have read storys about how hard these things are to remove all the air pockets and this may relieve those issues.
