Old 08-30-2008, 05:46 PM
Khill Khill is offline
IGN/ACC wire / where and which?
So I have a carpc which I have just replaced with a mac mini and carnetix p2140 power supply (totally irrelevant information). The power supply has a IGN wire which is used to start up and shut down the computer. My question is, what wire should I splice this with and where is it?
Thanks in advance!
Old 08-30-2008, 07:12 PM
maxwedge maxwedge is offline
A990 racer
Re: IGN/ACC wire / where and which?
Look for a ign powered terminal either in the under hood box or under the rear seat fuse/relay center.
Old 08-30-2008, 08:59 PM
Would it be possible to attach it to the ACC wire (ign1) on the ignition? If im correct this is pink? This way it comes on in the ACC position. A tap splice should do it correct?
Or is this a risky venture?
Old 08-31-2008, 09:51 AM
A990 racer
Your circuit has it's own fuse? I would still use an accessory feed out of one of the fuse boxes.
