Old 08-30-2008, 04:40 PM
Lonewlf455 Lonewlf455 is offline
1995 G/A Stalls When Hot
Hi. I'm new to the forum here. Hoping someone can shed some light on an issue with my Grand Am. Just bought it for my daughter. It's a 1995 Grand Am GT. 3.1 V-6 auto. It has 153,000 miles on it. When the engine is warm/hot, I put it into drive and it stalls. Won't stay running in Drive, however, it stays running in reverse? When the engine is cold it runs and drives UNTIL it warms up. I've replaced the TPS and it has no effect on problem. Something else if this has anything to do with it or not but when I revved it up to keep it running, the tach went up to 4000 and the engine started "missing" almost like it had a rev limiter on it. Thanks for any ideas in advance.........Ray
Old 09-02-2008, 03:47 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: 1995 G/A Stalls When Hot
Check the air intake hose for cracks past the MAF sensor. The engine rocks different ways in drive and reverse, so reverse may be sealing the crack and drive may be pulling it open.
There is a rev limiter on them, and in park/neutral it is set around 4k RPM.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
Old 09-02-2008, 07:54 PM
Thank you for the reply. I will check on it tomorrow and let you know what I find. This car is being a challenge. LOL
Old 09-03-2008, 06:32 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF Lonewlf455.
Sounds like you have a Torque Converter Clutch TCC going out, its located in your trans. This link has some helpful info and the replacement procedures.
http://autorepair.about.com/cs/doity.../aa011703b.htm
Hope that helps!
1999 Grand Am SS 3.4 OHV
Old 09-03-2008, 06:36 PM
The_Mechanic_33's Avatar
The_Mechanic_33 The_Mechanic_33 is offline
yes there is a rev limiter. also check fuel pressure.
Old 09-07-2008, 08:06 PM
Thanks!! I checked the intake air hose and it is fine, no tears or holes. Sealed up as well. I was doing some reading and I came up with the TCC as well. Going to delve in it soon. Thanks for the responses everyone. It helps a lot.......Ray
