00 Impala: Water coming from air cond. on pass side floor
00 Impala. Water leaking from blower motor when air is on.. Blower motor is shot now. There is a drain line off the blower motor and I blew that out but no help.. Where is the main drain for the evap system?
Also have a drip or stream from an area just left of the blower motor on pass side.. I think the drain line is clogged but can't find it... Last edited by zengel442; 08-30-2008 at 01:46 PM. Reason: Clarification of vehicle |
Re: Water coming from air cond. on pass side floor
Bump....
Re: 00 Impala: Water coming from air cond. on pass side floor
should be on passenger side firewall down near the bottom.you'll see a rubber tube coming out of firewall
I was thinking about blowing it out with air. Where does it start inside the cabin.. My leaking is at the passengers floor left hand side and the blower motor is dripping. Thank You
Bump
its easier if you can clean it from the drain on firewall.you have to split evaporator casing to get to the other end of drain.normally you can unclogg fairly easy with a wire coat hanger or simular go easy with the air.Good Luck
OK... Will do.... Thankx..
Son's car and it will be here again on Thursday.. Will give it a try.. |
Cant Send you a PM so:
Clearing AC Drain
