Old 08-29-2008, 04:04 PM
pu70 pu70 is offline
Hydroboost Master Cylinder Info Needed
I have a hydroboost and a master cylinder from a 92 Astro and need some info about the master cylinder. There are 2 ports cominig out the side of the master cylinder. Which one is for the front brakes and which one is for the rear brakes? Thanks
Old 08-30-2008, 10:57 AM
Blue Bowtie's Avatar
Registered Offender
Re: Hydroboost Master Cylinder Info Needed
Unfortunately, I don't have a '92 to compare. You can trace the lines to find out, or wait for a different answer. Typically, the larger fluid reservoir on the master cylinder is for the front (disc) brakes, and the line adjacent to the larger reservoir would route to that axle.
Old 08-30-2008, 01:14 PM
Thanks. I couldnt trace the lines back because they went into sime kind of ABS thing.
