Old 03-13-2003, 05:35 AM
BopperWI BopperWI is offline
Question Electrical Question, Engine Swap
I switched engines, by putting a 1990 3 banger into a 1995, I used the 1995 intake etc... but now I have no juice to the plugs. There's power on both sides of the coil and I believe one side should be ground out.
What did I miss?? Any ideas??
Old 05-15-2003, 06:35 PM
mattyoung33 mattyoung33 is offline
Send a message via AIM to mattyoung33
lol dude you have a metro.... HA
'99 Honda Civic HX
-17" ASA rims with Khumo's
-Lowered about 2" w/ eibach sportline springs
-KYB AGX full-adjustable gas shocks
-Injen cold-air intake
-Thermal full-catback exhaust
-Mugen style front/rear lips, type-zero sideskirts
-Grillcraft upper black grill
-custom painted interior
-strut bar
-hyper white headlight bulbs/piaa signals
-new paint job including painted side trim
Old 05-17-2003, 12:45 AM
SROfirefly1_0 SROfirefly1_0 is offline
Send a message via Yahoo to SROfirefly1_0
way bother saying crap like that????
lol dude you drive a civic.... HA
if you can't suguest anything. then don't say anything!
bad distributor(guts)???? did you change the cap and rotor????
its all about the twisties
Old 06-20-2003, 07:09 AM
lucyseabug lucyseabug is offline
You forgot to hook up the ground terminal to the engine/trans bolt located on the drivers side of the engine compartment. It is sticks out of the wire loom. I fought that one for 3 days. I had power to the distributor but it would not fire.
Good luck....
Old 03-13-2004, 11:46 PM
jmh_geoconvert' jmh_geoconvert' is offline
Re: Electrical Question, Engine Swap
hey, did u use the '95 distributor? I had the same problem with my '92 metro when i put an '89 engine in it with out changing the distributor. once i changed them out, it fired right up...maybe it'll help
Old 10-07-2004, 04:22 AM
lawbob81 lawbob81 is offline
Hi, I have a question about my GEO Metro '94. Today, my GEO just quit running. Its getting NO spark out of the coil, and no gas coming out of the injector. The engine was running just fine, and then stopped suddenly. Mechanically the engine is fine. Battery is HOT and alternator running good. It turns over with the starter no problem [just no spark or gas from injectors]. I've swapped out the coil assembly twice, I've swapped out the distributor in total [complete unit with cap and inside electric], the ECU/computer module, and all of the relays under the hood, but all to no avail. The coil is getting 12 volts to its imput\ terminal, but puts out no voltage at all to the distributor via the coil wire. The throttle body is getting 12 voltage, but again, no gas is being injected. What do you suggest is the problem? do you know somebody who would know how to diagnose ? Robert
Becker
