Old 08-28-2008, 05:59 PM
88honcivsi 88honcivsi is offline
wiring problem
I have a 88 honda civic standard model, i am having a problem with the car
the fuel pump doe not come on with key, u have to ground out the main relay i bought brand new
or the fuel pump wires at the computer. for the fuel pump to work.
my ? is, can i ground it out my self at the computer or the main relay to make the fuel pump work or will that cause more problems in future. if need more info please
leave message.everything i have done to it:
wiring : took dpfi wiring out, put in mpfi wiring from si, thats all of the wiring.
computer : si computer
engine : 1.5L D15B2
transmission : manual 5 speed
interior : si dash, si seats, si lower interior, standard upper interior
lights : took si tail lights
exhaust : factory header don't know what it came of of, performance exhaust.
wheels: 16 in
getting ready to add rear window wiper.
thanks, for the help if u can give any.
Old 08-28-2008, 07:18 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: wiring problem
Have you taken the main relay out and taken it apart yet? Do that and check the connections inside of it, might just be bad connections. Just re-solder everything and try it.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-28-2008, 08:16 PM
Re: wiring problem
bought a brand new relay, i don't think the old one was bad either.
Old 08-29-2008, 12:42 AM
Tony's Avatar
TLD Member #1
Re: wiring problem
Usually no need to buy a brand new one, just re-solder the old one.
I'm not exactly sure where the main relay grounds at OE, but if you can find it, I would check it. If not, I don't see a harm in grounding it, just so long as it still kicks on and off with the key as it should anyways.
Tony
Old 08-29-2008, 07:54 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Re: wiring problem
the relay should be grounded through the mounting point... iirc... if not, it's the black wire under the dash right near it... if i had a cam on hand, i'd take a pic of what I"m talking about right now and upload it... but there is a ground wire somewhere close to the relay.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
