Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 08-28-2008, 04:26 AM
wade623's Avatar
wade623 wade623 is offline
misfire cyl. 1
i have a 1999 malibu with a misfire on cylider 1 it idles roughly in drive but not in neutral and the c.e.l will only come on if it idles for more than 5 minutes then if i drive it with little idleing the light will turn of is there any thing i should check and how to check it before i take it to a shop
Old 08-28-2008, 06:15 AM
the great gazoo the great gazoo is offline
Re: misfire cyl. 1
I would pull out the spark plug and check it if it looks good swap it with another like #3 plug, check the plug wire make sure it is not burnt or broken or croded ends and feel the wire the entire length see if there any hard spots in the wire when bending it. when the engine is running check for spark at that plug. if you did all that and it all seems to be good and you have spark run the scanner again see if you transfered the problem to #3 cyl if it did you have a bad plug if still mis fire cyl 1 most likely bad injector
Old 08-29-2008, 01:33 AM
wade623's Avatar
Re: misfire cyl. 1
why would the light only come on after idleing and how hard would it be to change the injector
Old 08-29-2008, 07:38 AM
Re: misfire cyl. 1
I could not tell you why it only comes on at idle unless you have a bad plug or bad or loose plug wire or possible bad coil pack. but first check for spark. you can pick up a cheep spark tester for like $5 bucks at any large auto parts store I usally see them in the $5.00 bin when you first walk in the store. or do the ole timer way remove the wire from the spark plug stick a #3 phillips into the boot of the plug HOLD IT BY THE HANDLE of the screwdriver hold the shank of the screwdriver 1/4 inch away from something metal that is grounded, have a helper start the car if a spark keeps jumping from the screwdriver to the grounded metal you have spark.
Sometimes changing the fuel injectors are easy some are a pain some are as easy as reliving the pressure in the fuel system, un bolt the fuel rail, pull out the bad injector. reverse to install. some are more involved. but if you are not fimailer with injectors or not comfertable doing it i HIGHLY recomend you take it to a mechanic.
Old 08-30-2008, 03:02 AM
wade623's Avatar
Re: misfire cyl. 1
how could i tell if it is the coil pack because it is definitely missing because i can feel it and if i listen to the exahust it sound like it sucks instead of blows
Old 08-30-2008, 09:31 AM
Re: misfire cyl. 1
before you start to check for a bad coil pack check for spark at the plug wire. If you have a spark there the coil pack is good there are other reasons for mis fire other than no spark so try what i said in the last post and we will work from there. it is a good starting point to solve the problem
Old 08-31-2008, 04:15 AM
wade623's Avatar
Re: misfire cyl. 1
it has spark but when it idles it is definitly missing because i can feel the cylider hitting when it fires
Old 08-31-2008, 08:17 AM
Re: misfire cyl. 1
Ok since it has spark then it is not a coil pack. did you replace the plug ? if you did the next thing is fuel and compression. getting a compression tester and checking it would be the next easy step. but most likely fuel problem check for loose plug on injector for that cyl or replace injector.
Old 08-31-2008, 10:32 PM
wade623's Avatar
Re: misfire cyl. 1
ok, but was just wondering how many differnt kinds of injectors are there because i was looking how much they were and on the checker website it said the same injector fit 1996 f-150 and i have some of those kinds of injectors here
Old 09-01-2008, 02:32 AM
wade623's Avatar
Re: misfire cyl. 1
ok i think i figured out the problem the threads in the sparkplug hole are messed up and the plug would not go in all the way so does any body know if you can fix that by rethreading ot or what and can i do that myself or shold i take it in and if i should take it in about how much to get that fixed .thanks
Old 09-01-2008, 08:17 AM
Re: misfire cyl. 1
Ok check this out. you may find at your local auto barts store.
http://cgi.ebay.com/ebaymotors/New-1...spagenameZWDVW
Old 09-02-2008, 12:45 AM
wade623's Avatar
Re: misfire cyl. 1
thanks but i just made one of those out of one of the old spark plugs and it worked so the problem is finally solved yay
Old 09-02-2008, 08:19 AM
Re: misfire cyl. 1
Great News
Old 09-03-2008, 02:32 AM
wade623's Avatar
Re: misfire cyl. 1
went to autozone today and had them check the codes no codes are in the computer so it all good now
__________________________________
Practice makes less imperfections.
Old 09-03-2008, 01:53 PM
Re: misfire cyl. 1
Awsome, great news
