Old 08-27-2008, 08:28 PM
briang0 briang0 is offline
Outside Driver door handle removal
I have a 94 Silverado 1500 I want to replace the outside door handle on the drivers door. I took the panels off and I have removed the 2 10mm bolts the one on the inside and the one on the side. I removed one of the rods to the lock mech but there is one other rod I can't figure out. Does anyone have any info on the removal of the assembly? I putting on a new door and want to bring the lock over from the old door to the new one.
Old 08-27-2008, 09:18 PM
jefferson123 jefferson123 is offline
Re: Outside Driver door handle removal
You have 2 lock rods one for outside handle one for inside handle the same goes for the outside and inside latch.4 in totall,good luck
Old 08-28-2008, 07:14 AM
bigcoconut bigcoconut is offline
Done this couple of times and it don't get any easier. The second rod is behind the window track, you'll have to bend your hand around to get at it and pull it off. I call it a "blind" assembly, meaning your going be feeling around to work with this one.
Be patient, it can be done...
"Yes I have a truck and No I won't help you move your stuff..."
2008 Kawasaki KLR650 2500mi (fairweather commuter)
1992 C1500 Silverado 235,000mi (daily, not so much anymore, driver)
1999 Venture 120,000mi (moms vacation bus)
1989 Dodge Ramcharger SOLD, Yee-Freak'in-Haw
