Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-27-2008, 06:45 PM
brianne79 brianne79 is offline
89 cutlass supreme wont start
After driving my car and it has warmed up and i shut it off, sometimes when i go to start it again it wont start. It does nothing. I then have to wait anywhere from 5 minutes to hours before it will start again. Any suggestions? Could it be the knock sensor?
Old 08-27-2008, 09:07 PM
inafogg inafogg is offline
Re: 89 cutlass supreme wont start
do you wait longer for it to restart the longer you drive before you shut off??
i'd say no on the knock sensor..
''it does nothing'' does this mean no cranking??or cranks but does'nt start??
Old 08-28-2008, 07:15 PM
It does nothing meaning no it doesnt crank. I have power to everything else, it just wont start.
Old 08-28-2008, 07:35 PM
maxwedge maxwedge is offline
A990 racer
Check battery cable connections and grounds, also check for 12v to the starter solenoid when trying to crank, ( 2 man job), if you have it the starter is bad.
Old 08-28-2008, 08:24 PM
Chevy59Diesel Chevy59Diesel is offline
OR the starter could be bound by heat from the exhaust down pipe. A heat shield helps. Maybe
