Old 03-12-2003, 11:22 PM
ef8gen4 ef8gen4 is offline
help i need somebody
ok hi i have a 90crx dx i am trying to put a 99gsr or b18c1 motor with a y1 trany and pr3 ecu in my car what else do i need..?
i also have hasport motor mounts and place racing shift linkage. please i need lots of help.
Old 03-13-2003, 01:49 PM
zippeay zippeay is offline
you need the GSR drive axles and you need to wire up the Vtec and plug up the ECU. Good luck
:monkeypis FORD
Old 03-14-2003, 06:02 PM
jcrx jcrx is offline
Send a message via AIM to jcrx
First your going to have to convert to MPFI,then you can start thinking about putting the GSR in.Then your going to have to make a dent in the drivers side frame to fit te altenator pulley.Then your going to have to run a ECU that supports the IAB.
Old 08-21-2003, 11:46 AM
Dreem Dreem is offline
Hey ef8gen4,
Don't forget you'll need money.
