Old 08-27-2008, 02:33 PM
janositamas's Avatar
janositamas janositamas is offline
Molding lines misery
Hi Guys, I have a problem that occurs nowadays concerning molding lines: after sanding the molding lines on the bodyshell, I primer the body. Everything is smooth and nice at this point. I always use Dupli Color car paint on my kits, works well with no problems. I bought some cans of Dupli Color Mirage flip flop effect spray paint which requires a black base to bring out the paint shifting effect. The molding line start to appear after painting the black base. Then I sand it down again to have a very flat and smooth surface and paint a layer of black again. At this point, everything is nice again. Than I spray the color effect paint, and molding lines appear again after the paint has dried. Do you guys have any idea what the problem can be??? It drives me crazy, especially because it has never happened to me before! Any help is appreciated! Thanks!
Old 08-27-2008, 02:54 PM
freakray freakray is offline
AF Modelrater
Re: Molding lines misery
It's commonly referred to as 'ghosting', I know some good solutions have been posted before.
If we can get the search feature to work, we could find the threads
EDIT: Found some:
http://www.automotiveforums.com/vbul...ht=ghost+lines
AF User Guidelines
Old 08-27-2008, 11:08 PM
CFarias's Avatar
CFarias CFarias is offline
Try applying the duplicolor primer sealer. This has solved the problem for me.
Old 08-28-2008, 08:47 AM
Thanks guys, both of you! I didn't know it is called ghost lines, but now I know what to do next time. It is a pity it has happened to my new Tamiya GT-R , it is high-time to buy a primer sealer. Thanks again!
Old 08-28-2008, 11:05 AM
BVC500 BVC500 is offline
I don't think I've ever experienced this in 20 years of modeling. Hmmm....weird.
Old 08-28-2008, 03:41 PM
daniel_k daniel_k is offline
I had the same problem on Tamiya Peugeot 206 WRC...the ghosting appeared right after priming and wouldn't go away with more layers. I stripped the paint and used some coarse paper and sanded away the ghosting, puttied it and primered again. Now it's perfect.
daniel
-germany-
Old 08-29-2008, 08:58 AM
ChicoBR ChicoBR is offline
There is an easy and quick cure fo ghosting:
After you sand the molding line, apply with a brush liquid cement over the sanded mold line and let it dry for 24 hours.
After itīs dry, prime and paint. No more ghosting!
The liquid cement will act as a barrier to the ghosting effect.
I use the Tamiya extra thin liquid cement for that and it works perfectly.
Chico
Old 08-29-2008, 11:25 AM
Spike2933's Avatar
Spike2933 Spike2933 is offline
Send a message via Yahoo to Spike2933
were guys like were gonna waste time on the search button
Steve
Old 08-29-2008, 02:32 PM
AF Modelrater
The humor was lost on you - my point was that the search button doesn't work
AF User Guidelines
