Old 08-27-2008, 11:37 AM
y2kpa2's Avatar
y2kpa2 y2kpa2 is offline
Village Idiot
oil pressure/ cabin air filter
on my 2000 park ave i was wondering if anybody has had the experience of changing the cabin air filter i know where it is located and have tried to remove it but with no luck and not wanting to break anything.. another question on my driver info center my oil pressure reads 129 psi NORMAL???? I know that is also not the correct pressure
and the battery voltage reading is always alot lower than the actual at the battery... and when i put down the drivers side power window the blower motor stops and sometimes the driver info center will go blank and the dome light will come on for a few seconds but if you gauge the actual battery no major change while this is happening????? any suggestions.......
thank you
Old 09-01-2008, 12:51 AM
knelson276 knelson276 is offline
Re: oil pressure/ cabin air filter
thank you
dont know about your cabin air filter but the electrical problem sound like a bad connection somewhere. Since the systems your describing will be on sepreate fuses on the +12 side I'd be looking for a poor ground somewhere in the cabin. some where in another post there was mention of a ground bus located under the drivers side sill. this was effecting the power windows and a couple other problems. not sure if its located in the same place for all years of the park avenue but could be a good place to start.
Old 09-01-2008, 01:54 AM
Scrapper Scrapper is offline
AF Premium User
look between your car door when it's open theres rubber boot your wire run threw on each side that controls all that...and filter i wouldf keep reagular filter in it if your talking air filter kn's are junk you put to much grease on them they plug up maf,tbs like i say if your talking air filter?
Old 09-01-2008, 09:00 AM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Cabin Air Filter
Old 09-01-2008, 11:31 AM
y2kpa2's Avatar
Village Idiot
thank you guys
will give updates
