Old 08-26-2008, 10:36 PM
jefferson123 jefferson123 is offline
TPI to Carb
I know this has been disscussed many times,but i need to know.I have a 1999 2500 4x4 and i want to put on an edelbrock with a 600 cfm.Is thier anything else i should know like distributer? or automatic shift cables? Please help.
I have had enough of this pile of **** fuel injection.Very costly airflow sensors,o2 sensors and the list goes on.
Old 08-27-2008, 06:55 PM
Re: TPI to Carb
Sorry folks maybe i came to the wrong forum for this information.Just looking for somebody that actually had some mechanic smarts.
Old 08-27-2008, 07:35 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: TPI to Carb
It can be done but it is an expensive conversion and you will be running afoul of federal and/or California smog laws in doing so - potentially subjecting yourself to a $25,000 fine. If the engine is an LS type (Vortec 4800/5300), you will need a special front cover that fits a Ford small block distributor (it is available, can't remember the GM part # off the top of my head), plus a special carb intake. If it's a small block Gen 1 engine, you will need a carb type Vortec intake (earlier ones will not work), plus a vacuum controlled HEI distributor.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 08-27-2008, 08:31 PM
wafrederick wafrederick is offline
Banned
Re: TPI to Carb
It will run like crap, cold blooded and I know of one doing this in a 1991 Chevy truck.Was converted to a carb,would not run right,had to pump it a few times and ran like crap.Electronic Fuel Injection is more reliable than a carb.The carb has more parts than EFI and that is one reason why automakers switched to EFI.
Old 08-27-2008, 09:02 PM
Re: TPI to Carb
Thanks silicon but not worried about smog laws as i live in Northern Canada,and they dont check this far up.Engine is a 1999 vortec 5.7 and i planned on putting on a edelbrock vortec,but wasnt sure of HEC or automatic trans shift cables.
Old 08-27-2008, 09:09 PM
Re: TPI to Carb
Automakers did not switch because of moving parts,they switch because it was more efficient and responsive in MOST cases, but not all.
As far as a 91 goes thats TBI not TPI,and thats simple to change to a carb,and make it run efficient.
Old 08-27-2008, 11:04 PM
2000CAYukon 2000CAYukon is offline
Re: TPI to Carb
You will need an aftermarket controller for the 4L60E/4L80E tranny (not sure which one you have). TCI makes one GM might even make one. There are no shift cables. You could switch to 700R4 and use a vacuum switch to do TCC lockup but the 4L60E/4L80E will require a controller.
//2000CAYukon
Old 08-28-2008, 07:12 AM
Re: TPI to Carb
//2000CAYukon
Thanks yukon, i will definately be purchasing a controller for for the 4L80E,but what or who is TCI?
Old 08-28-2008, 09:51 AM
Re: TPI to Carb
Here is the link to TCI's Controller http://www.tciauto.com/Products/Electronics/default.asp
Ebay may also have some. GM Performance Parts may also make a controller.
//2000CAYukon
Old 08-28-2008, 03:34 PM
Re: TPI to Carb
//2000CAYukon
Yhanks a bunch yukon
