Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 08-26-2008, 08:09 PM
prozler prozler is offline
power windows and moonroof
hello all
i have a 1999 ford explorer and all of a sudden the all power windows dont work along with the moon roof and also at same time 4x4 high and low lights started flashing.i have checked all relatated fuses and relays and all have power and seemed to be working.i have no power at the window switch along with moon roof switch....please help thanks paul
Old 08-26-2008, 10:53 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: power windows and moonroof
Welcome to the forum!
There are a couple of relays and fuses that are common to both the power windows and the roof. Have you checked fuse #4 in the Battery Junction Box (30A) and fuse #26 (10A) in the Central Junction Box? Fuse #4 is for the Accessory Delay Relay and Fuse #26 is for the Battery Saver Relay.
-Rod
Old 09-23-2008, 07:26 PM
Tugger Tugger is offline
I had the same problem with a 96 Eddies bauer explorer I had....one day, none of the power windows or moonroof would work and the 4x4 flashed but wouldn't engage....mechanic suggested a new GEM module and this fixed all my issues...I'd check the first cheaper suggestions first obviously....good luck
