Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 08-26-2008, 06:07 PM
jeremy06 jeremy06 is offline
Send a message via Yahoo to jeremy06
traction control switch
My traction control switch is lit up and I can't make it go off, the light in the speedo cluster is off. So is it on? Is it off? Do I need to fix it somewhere?
Old 08-26-2008, 06:12 PM
RC1488 RC1488 is offline
Re: traction control switch
More than likely the switch is broken. Junk yard is your best bet. If the light is on the traction control is ON. Meaning it is monitoring the wheels vs the rpms of the engine. Only when the system is needed and actually effects the engine, does the TRAC light on the cluster go on.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 08-27-2008, 09:08 AM
The traction light in the cluster comes on briefly while starting up. It goes off after the car is running, but the switch above the radio is lit up all the time and can't be turned off.
Old 08-27-2008, 11:39 AM
Thats normal. The system is most likely doing checks, just like the abs does it upon start up.
As i said before, you may need a new switch
