Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 08-26-2008, 02:03 PM
lilrogue78 lilrogue78 is offline
Angry Egr? anything? my fuel economy sux...
okay i got a 1996 Neonator (2.0 DOHC Automatic) which should get amazing mileage and it used to but now i have an issue i have an egr code and i am getting tired of changing neon egrs so i was thinkin who needs it i want to take my egr off and make an intake backoff plate to bypass the portion and put a plug in my exhaust tube because i am thinking my egr is at all times staying open and pushing way to much exhaust gasses into my poor mini engine problem is will i harm my mileage or performance with this little evil plan i have? it seems to be the absolute most efficent way to run my engine
Old 08-27-2008, 07:25 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: EGR .....Get Bent..... please help
You can block it off and it won't affect the engines performance at all. You will however get a CEL for the code 32 (EGR).
2003 Dodge SRT-4
Old 08-27-2008, 08:48 PM
okay if it wont affect the performance any will it possibly affect my fuel economy? i had figured it would enhance the Performance/Fuel Efficency due to the engine running on cleaner gasses. I have also recently noticed a large loss in my mileage (such as about 90miles from toped off to half) running it nicely and i do not have any other codes other then the EGR (32) Acually i had busted off the o2 sensor after the cat and was still getting descent mileage then it droped around the time i put a new one in. Here is the deal tho i had an extra o2 sensor from my lebaron which looked identical to the old one so i installed that but i had cut the wires origonally so i respliced them togeather from the neon harness (wht to wht brn to brn blk to blk and wht to wht again) but i had wondered if the two whites acually had different functions and if i may have attached them incorrectly it seems as tho its correct due to no codes....
Old 08-27-2008, 10:14 PM
A bad functioning EGR can hurt fuel economy. Dont know about the O2 sensor problem since I haven't looked at the wiring diagram for a Lebaron.
2003 Dodge SRT-4
Old 08-28-2008, 09:51 AM
and how badly should it harm my economy because i aint got shit for mpg these days and if i made a block of it would help increase the mpg again correct? or is there anything else i shoul look into?
Old 08-28-2008, 09:53 AM
It can lower it by about 50 miles per tank.
2003 Dodge SRT-4
Old 08-28-2008, 09:54 AM
ouch so down to about 20 mpg
Old 08-28-2008, 09:56 AM
anything else you could possibly think of that would cause it to drop so drasticaly? also are the white wires on the o2 sensor sensitive of which ones connect to which? i am about to just quit running to o2 it seemed to have better mpg before i re attached it
Old 08-28-2008, 09:57 AM
Thats what a bad EGR did to me.
2003 Dodge SRT-4
Old 08-28-2008, 09:59 AM
the thing that i noticed that was strange is that i had an egr code seince i got the car and was getting great mileage then it just disappeared(the gas mileage) do you think the fuel filter could be causing this as well?
Old 08-28-2008, 10:12 AM
I wouldn't look at the fuel filter as long as the car is running well. It wouldn't hurt your fuel economy. But rather make it stumble and misfire.
2003 Dodge SRT-4
Old 08-29-2008, 12:45 PM
well i unpluged the o2 sensor and increased the mpg by a small amount (strange huh?)
Old 08-29-2008, 12:47 PM
Could be hooked up wrong.
2003 Dodge SRT-4
Old 08-30-2008, 12:03 PM
kinda what i thought
