Old 08-26-2008, 12:24 PM
kevbayer kevbayer is offline
window issues - driver's side is the only control that works
So among my other issues, my windows can only be controlled from the drivers side control....my lock is not on...So I know that i need to check my connection, but how do I get to under the control to check it out? looks like it is glued pretty tight in, is there a screw or something i am missing?
Thanks!
Old 08-26-2008, 01:29 PM
LittleHoov's Avatar
LittleHoov LittleHoov is offline
Send a message via AIM to LittleHoov
Re: window issues - driver's side is the only control that works
Pull hard from the bottom side, the side closest to the door handle if you were sitting in the drivers seat.
Dont pull from the top side or youll break the plastic clip.
Its actually not glued on, but uses a plastic tab and a big metal clip to keep it in place. But it will just pop off, and all the other doors are the same way.
2000 Oldsmobile Intrigue 3.5 DOHC V6
Mods: Fenderwell Intake, High-Flow cat, U-bend delete, 12-inch front rotors, GMPP handling kit, 20% tint, Pioneer front and rear speakers, Eclipse HU, cleared corners
1986 Jeep Cherokee 2.8 V6
