Old 08-26-2008, 05:15 AM
caddydaddy83 caddydaddy83 is offline
led display only bottom half lights
in my 83 caddy radio the led only lights up on the bottom half how do i fix it
Old 08-26-2008, 06:54 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: led display only bottom half lights
good lord, if that's the OEM radio then it has lived a long life. It probably has some burned out lights/leds or loose wiriring inside. You would have to take it apart and see.
Old 09-02-2008, 07:50 PM
AWP9521 AWP9521 is offline
Definitely bulbs in a 80's era factory radio.
Replacing them is another story depending on how the radio is put together. My experience is with the Chrysler radios and their faceplate is held with 2 screws and clipped to the radio chassis (locking plastic tabs on the faceplate sides), removing the plate exposed the bulbs and some were actually servicable with bulbs from an auto parts store, just had to remove the colored covers and put them on the new bulbs and replace. I can't speak for the GM units but if your adventurous and want check it out you may be able to replace them just by doing the same.
No guarantees though, may be time to give the caddy some new sounds.
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
