Old 08-26-2008, 12:37 AM
ljrstrudel ljrstrudel is offline
89 c1500 5.7 starts then stalls...
The truck will start and run for about 10 +/- seconds then stall. Has fuel and spark. This problem started after battery change, have replaced IAC Valve, Fuel Pump Relay, EGR Valve, MAP Sensor, Distributor, Coil, batt. cables, as well as Ignition switch and module. Cap, rotor, plugs, plug wires, and fuel filter are in good condition and less than a year old. Fuel Pump Primes and runs until engine stalls. After a few tries it will stay running but only for about 20 +/- miles, then cuts off (always at worst time), or sometimes it will run fine, then shut it off at store ect. and starts then stalls again. Please Help I have been fighting this thing for too long and am running out of patience (and $).
Old 08-26-2008, 12:56 AM
Scrapper Scrapper is offline
AF Premium User
Re: 89 c1500 5.7 starts then stalls...
coil could be weak if it's the same one? or mabe got a bad fuel pump? egrs its the time of the year when they go.you can try to clean it or replace it.
Old 08-26-2008, 01:04 AM
EGR? The valve or the sensor? Sensor is new. Coil is about 8 months old, MSD
Old 08-26-2008, 08:30 AM
bigcoconut bigcoconut is offline
In your description, did you change the Ignition Control Module, the little black thingy with two electrical connections that sits just under the distributor cap? My 92 gave me similar heart aches awhile back just after a good tune-up and it was the ICM. When that little booger gets old they can't handle the heat anymore, start acting erratic or not at all.
Just my .02 worth...
"Yes I have a truck and No I won't help you move your stuff..."
2008 Kawasaki KLR650 2500mi (fairweather commuter)
1992 C1500 Silverado 235,000mi (daily, not so much anymore, driver)
1999 Venture 120,000mi (moms vacation bus)
1989 Dodge Ramcharger SOLD, Yee-Freak'in-Haw
Old 08-26-2008, 11:24 AM
Yes the distributor came with a new module. But thank you.
Could it be the fuel filler cap?
Old 08-26-2008, 07:19 PM
777stickman 777stickman is offline
More ?'s!!! This all started with a simple battery change? In other words did you change the battery because of this problem?
Have you checked the Alt output to the Batt? Should be around 14.2 volts.
I've underlined what you posted about the fuel pump. If it quits running the motor is going to quit running. If that's the case you need to check wiring and grounds to the pump. If all that's good then maybe the pump itself.
As far as the filler cap, it could be a possibility.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 08-26-2008, 10:57 PM
AF Premium User
no i don't think gas cap made that much diffirence as long ast it fit. now days you have to have the right one or check engine light will come on like my wifes 2006 malibu...
