Old 08-25-2008, 11:48 PM
3000-GTO's Avatar
3000-GTO 3000-GTO is offline
I am confused
On my way back from class tonight I noticed my car was running a bit hot. I first tried turning on the heater but I couldn't feel any hot air at all. I then proceeded to pull over to check my radiator to see if coolant was circulating. My radiator was warm so I know my T stat is fine(I replaced my T stat about 2 weeks ago).
I got back in my car and started it up again then turned on the heater drove about 20 feet and then the temperature instantly dropped and I felt hot air through the heater. I'm guessing coolant isn't circulating somewhere but not sure exactly what's up. My car has actually done this several times now. It will heat up about 2/3 of the way on the gauge and then drop within a couple seconds. Thanks for the help.
Old 08-26-2008, 04:52 AM
toymaker3000gt toymaker3000gt is offline
Re: I am confused
im no expert but im thinking it might be the water pump dude maybe some of the other guys could give u some ideas. even though they didnt give me any aswers good luck
garydowless/@ myspace.com
Old 08-26-2008, 10:54 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: I am confused
If it was the water pump he would notice a leak.
It sounds like you may have an air pocket in the system.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 08-26-2008, 11:12 AM
AutostradaVR4 AutostradaVR4 is offline
Re: I am confused
+1
make sure it's as full as possible. If it's not that, i would try replacing the thermostat again. I've had a brand new one go bad in a week, so it's possible.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 08-26-2008, 11:53 AM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: I am confused
If coolant is low it will bypass the heater hoses. You probably have a leak somewhere.
Old 08-26-2008, 01:00 PM
3000-GTO's Avatar
Re: I am confused
So why would it start working again? I just replaced my water pump not too long ago but I guess it's possible it is leaking. Guess I'll have to check everything.
Old 08-26-2008, 03:34 PM
Re: I am confused
But he could also have a leak and just didnt see it im not saying that it is the water pump im just saying that i sounds like thats the problem to me!
Old 08-27-2008, 08:12 PM
DCIV's Avatar
DCIV DCIV is offline
Re: I am confused
if heat isnt coming out then your heater core prob isnt working properly. If its the stock rad then you might want to think about changing it as most these cars still have stock rads and they are getting old.
Coop
Old 08-28-2008, 02:00 AM
Tazbong Tazbong is offline
Re: I am confused
I would check the slack at the water pump on the timming belt.After tearing mine down for a full rebuild i noticed that the belt was not correct.If you did the water pump not that long ago you were just in there. hope it helps No leaking required
Old 08-28-2008, 02:07 AM
3000-GTO's Avatar
Re: I am confused
Coop
I actually changed the radiator out for the 3sx high capacity so that's fine.
I noticed some coolant dripping from my car the other night. So I think it is definantly a leak at this point.
Old 08-28-2008, 11:39 AM
Stealthee's Avatar
Re: I am confused
If there was slack he would have jumped time.
What you probably experienced was the auto tensioner doing its job of letting a little bit of slack in the belt when it sits. As soon as the car is cranked the tension is taken back up.
Old 08-28-2008, 04:32 PM
Re: I am confused
dude make sure u check that water pump for leaks real good make sure all the bolts are tight! if its not that check all your hoses make sure they or tight and check to see if they collapes any when car is running! if they are old and collapesing they maybe preventing coolant from moving like i should just an idea good luck
