Old 08-25-2008, 01:46 PM
94Gtp_prix 94Gtp_prix is offline
94 grand prix GTP runs real hot/overheatin. replaced pump and thermostat,still hot!!?
ive had this car a cupple month its been running fine, replaced water pump and it rane fine for a month or so then started ridding hot, now i can only ried it like 5 mils and have to pull off n let it cool down, ..replaced thermostat, hopein that woul dhelp but it just slowd it down a little, taking it a cupple extra mins to get hot,. and when i say i i mean hot, when it hits running temp of about 210 it just keeps goin up , 260 into the red and i have to pull over.
i havent a clue what the hell is wrong with it, but intill i find out i cant fix it, so step 1 find out whats wrong, maby then i can fix it,
thanks to any one that can help!
Old 08-25-2008, 03:13 PM
GoBears's Avatar
GoBears GoBears is offline
Re: 94 grand prix GTP runs real hot/overheatin. replaced pump and thermostat,still ho
Hi and welcome to AF. Are your cooling fan(s) coming on when they should be? Do you have any SES lights? You could have air in your cooling system that will cause overheating as well. Be very careful letting your engine get that hot, it doesn't take much to do damage.
2000 Pontiac Grand Prix GTP
Old 08-25-2008, 03:17 PM
Mr3GTP's Avatar
Mr3GTP Mr3GTP is offline
Re: 94 grand prix GTP runs real hot/overheatin. replaced pump and thermostat,still hot!!?
Did you bleed the air out when you refilled the cooling system?
Air pockets will block coolant flow and cause overheating.
EDIT; Nevermind, typed too slow.
'88 Tempo LX 5-speed, supercharged & intercooled 2.3 HSC.
http://www.cardomain.com/ride/690230/1
Old 09-07-2008, 01:22 AM
shaunaz25 shaunaz25 is offline
i have the same problem w mine. ive taken it to jiffy lube twice they did a complete rad flush. u would think there wouldnt be any air pockets
Old 09-07-2008, 01:39 AM
Scrapper Scrapper is offline
AF Premium User
have you looked and seen if fans are running as the other guy told you? if they run you may have clogged raidiater or head casket leak radiater is circulating isn't it. do a compresion on all cyl. really souds like head gasket.but check plugs a compresion test.i doubt be cadlitic converter but need check that also. just go from there see what show's up.
Old 09-07-2008, 01:43 AM
could it be the engine coolant sensor? a fews months back check engine light came ran the codes, engine coolant sensor. replaced but replaced thermostat as well. runs hot ever sense. replaced them both 1 more time just in case...
Old 09-07-2008, 01:44 AM
also to get both fans to run i have to have ac or heater on, and sometimes that doesnt even help.
Old 09-07-2008, 01:59 AM
AF Premium User
if you replaced water pump then radiater is not circulaiting? then i would think head casket or could you have got timing off after replacing water pump.
Old 09-07-2008, 10:13 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
You can also make both cooling fans turn on by simply unplugging the ECT sensor for the ECM. (sometimes there are two, one for guage and other for ECM). Unplug it, and start the car. Within a few minutes, the ECM will kick on both fans as a failsafe because it lost the ECT signal.
If the fans dont come on, check out the fuses, and maybe swap the relats around. Could also check for voltage at the fans.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-11-2008, 11:47 AM
pass6143 pass6143 is offline
Sounds like your next step should be to take a look at your coolant temp sensor. From the sound of it you've tried everything else. Good luck.
EP
