Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 08-25-2008, 07:29 AM
aluckyguy75 aluckyguy75 is offline
Unhappy Now What Wrong
I have a 94 Chevy Lumina APV 3.8.
I have changed all of these parts in the last 2 weeks
spark plugs and wires
fuel filter
harmonica balancer
tension pulley
water pump
knock sensor
starter
emptied the gas tank and cleaned it out added fresh gas and treatment
new oil and filter
new air filter
The check engine light comes on when you start it and it will spudder for 15 mins then it will drive good. Shut it off come back a few hours later and you have to let it warm up for another 15 mins. And the engine gets really HOT but it doesn't over heat is this normal both fans work
Old 08-27-2008, 08:06 PM
Lumina94APV Lumina94APV is offline
Re: Now What Wrong
Your post looked a bit lonely - so thought I'd reply
First a dumb question - did the problem exist before changing all the parts???
Get it scanned for any trouble codes- if the check engine light comes on it should store a code in the PCM.
If it gets really hot - suggest checking/changing the thermostat. The fans should normally cycle on and off or stay on when air conditioning is on...
Allan
Old 08-27-2008, 08:28 PM
Re: Now What Wrong
It had a knocking noise so I changed the harmonic balancer then everything else went down hill after that
Old 08-28-2008, 03:15 PM
Re: Now What Wrong
I'm no expert - just know enough to be dangerous...
Maybe the crank sensor was damaged or wiring to it was disturbed when harmonic balancer was changed?? A search on crank sensor - shows lots of posts on this, some consider it a common item to replace. So far, I've had no problems with it...
Some places will scan car for codes for free, so if you can do this will help with the diagnosis.
Check http://www.automotiveforums.com/vbulletin/t636131.html and
http://www.avigex.ca/xport/dtc18.jpg
http://www.avigex.ca/xport/dtc18procedure.jpg
(The code for a '94 is DTC P0341 but testing is the same.)
Allan
Old 09-03-2008, 11:02 AM
Re: Now What Wrong
everything looks alright with the crank parts and plugs checked everything. I have no clue whats wrong with it guess I'll keep trying
