Old 08-24-2008, 07:17 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
ODBI Distributor wiring
Ok, I'm having a stupid moment here, but I'm converting my other hatch to OBDI. I already have the Boomslang harness for it, but I'm working on making a jumper harness for the distributor.
Now the instructions say that all the distributor wires match up except the "Large" white wire on the OBD0 side needs to go to the Yellow/Green wire on the OBDI side. My problem is there is no "large" white wire, the is only 2 white wires, same gauge. I'm assuming the lone white wire is the one they are talking about because all the other wires are paired together further down the harness.
Some one correct me if I'm wrong here.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-24-2008, 08:49 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: ODBI Distributor wiring
http://www.homemadeturbo.com/forum/i...?topic=49667.0
3rd post down they talk about stripping back the loom to find the unshielded white wire. Don't know if that helps any.
Old 08-24-2008, 10:07 PM
Tony's Avatar
TLD Member #1
Yep, that is the solo wire, that is the way I wired it up. Couldn't find my damn heat shrink so I just used some liquid electrical tape on it. I have the jumper harness done, working on doing all the MPFI wiring now.
Tony
Old 08-24-2008, 10:37 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Yeah you got it right, the one thats not loomed with the rest is your igniter output.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 08-25-2008, 12:22 AM
Tony's Avatar
TLD Member #1
Frodo: On the y8 does it have one or 2 sensor's above the oil filter on the block? I've noticed my z6 only has 1 there while my d15 and b18 both have 2. I have to find another sensor for there, but don't know which one it is, lol.
Tony
Old 08-25-2008, 04:42 AM
FrodoGT's Avatar
Well the y8 has a knock sensor, and oil press sensor. I dont recall anything else under there. the b18 you have is obd0 right? So itll have the radiator fan switch on it as well instead of the thermo housing like the z6/y8, that's prolly what your seeing.
Current project:
Rio Red 91 hatch.
Old 08-25-2008, 12:45 PM
Tony's Avatar
TLD Member #1
Just thought about this, but do I need to re route those 2 wires up to the thermostat housing for the new thermoswitch?
Tony
Old 08-25-2008, 10:39 PM
FrodoGT's Avatar
Yup yup. Oryou could be like the previous owner of my car when they put a d15b7 in and still ran on dual port.. jumped the plug with some wire and a ball of aluminum foil shoved in to hold it. Oh well, at least there wasn't a single cut wire on the car till me.
Current project:
Rio Red 91 hatch.
Old 08-25-2008, 11:02 PM
Tony's Avatar
TLD Member #1
Wow...that was nice of them.
I finished the Distributor jumper harness today, didnt work on it much. I was going to get some heatshrink and put over it, but forgot that only Autozone has the rolls of it. So it has liquid electrical tape around the actual soldered connection, then I wrapped each wire individually with electrical tape, then all together with it. I would have prefered the heat shrink, but I think this will work fine also.
Once I stop being lazy, I will finish the chassis side of the MPFI/OBDI wiring and then work on the engine side of it all before I install the engine in the car.
Tony
Old 08-26-2008, 04:49 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
lol tony... laziness seems to plague those of us that DO everything ourselves... lately.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 08-28-2008, 02:14 AM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
is this boomslang harness like the rywire harness with the 7 or 8 extra wire you have to hook up for the o2 sensor and so forth. im also needing to convert to obd1 for my engine/turbo swap.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 08-28-2008, 07:22 AM
Tony's Avatar
TLD Member #1
Yes, it comes with the jumper harness for the ECU and there is also 2 extra plugs(atleast on the DPFI version) for the extra wires for Vtec, O2, knock sensor, IAB, injectors and distributors. Comes with some nice instructions also, I am very pleased with the harness.
Tony
Old 08-28-2008, 05:38 PM
well im lucky on the dpfi think that was done a few years ago. is there anthing really outta the ordinary that isnt to well explained or noted down.
06 cbr 600 f4i
91 civic hatchback.
Old 08-28-2008, 07:25 PM
Tony's Avatar
TLD Member #1
http://www.boomslang.us/obd0_1.pdf
Complete copy of the provided instructions
Tony
Old 08-29-2008, 09:03 PM
man i really need to brush up on my wiring and such.
06 cbr 600 f4i
91 civic hatchback.
