Old 08-24-2008, 02:18 PM
McLin's Avatar
McLin McLin is offline
Brake light problem...
I have a problem when I brake and turn on the turn signal just the middle brake light works and the flasher but not the brake light on the other side, same on other side...
when I push the brake pedal without turn signal all works fine, have anybody an idea?
Best regards McLin.
My Lumina
My Girlfriends Lumina
Mileage:
Old 08-24-2008, 02:40 PM
Scrapper Scrapper is offline
AF Premium User
Re: Brake light problem...
have you changed the bulbs around and see if you get a diffirent light patern? and have you checked wires and socket to see if there turning green and not getting a good conection. i really don't think i'm understanding you. because it could be a number of things like turn signal switch or down by your brake pedal.or change and put new sockets in your brake lights? could even be bad ground. you tested all fuses right? and have you chcked with test light see where a wire is braking down? theres a few tho's things i'd check.good luck..
Old 08-24-2008, 02:50 PM
McLin's Avatar
I didnt change the socket or the lights, but I will check it, when I stop on a crossing an will turn left or right and brake when the turn signal is on the other side brake light goes off and the middle is every time on when I press the brake pedal, when I just brake all brake lights working...
When I turn on the turn signal without brake all works fine, the problem is just when I brake and turn signal is on...
Best regards McLin.
My Lumina
Mileage:
Old 08-24-2008, 08:47 PM
AF Premium User
Question Re: Brake light problem...
be sure you check down at your brake pedal as i said eailer. mite be wire down there that conects.
Old 12-29-2008, 03:59 PM
McLin's Avatar
Hi,
when I move the turn signal switch to high beam position the brake light goes on when I brake and turn...
How much cost a turn signal switch? Or can I repair the switch?
Best regards McLin.
My Lumina
Mileage:
