Old 08-23-2008, 09:48 AM
dbaker1014 dbaker1014 is offline
fans wont shut off
For some reason my fans wont shut off on my 98 t&c unless i pull my fuse, just started happening. could it be my temp sensor? I cant see my relays going bad on both of them.
Old 08-23-2008, 09:59 AM
Scrapper Scrapper is offline
AF Premium User
Re: fans wont shut off
theres a module should be up by firewall. i changed 1 about year ago on my sisters pa it was kinda of a bear to get to but it worked...good luck...
Old 08-23-2008, 03:37 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Based on several recent posts it's usually caused by the single solid state relay that controls both fans. It's called the cooling fan relay and it's mounted on the frame next to the radiator down low on the driver's side. They cost around $50.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 08-25-2008, 08:51 PM
triplethreattt triplethreattt is offline
i replaced mine recently when it went the other way, and PREVENTED the fans from coming on.
Doubling up my problem was that when the first one went out, it also burned the connnector, which is also a common problem, apparently. I got that part at the dealer
Just in case you pull it off, and see burn marks...here's the part number (I have a 98 Gr Voyager, and assuming it's the same part)
5013979, and my price was $26.36. Again, this was for the connector. The relay you can get at any Auto Parts place.
08 Honda Fit - 45,000 miles
08 Honda Odyssey - 32000 miles
97 Lexus ES300 - 175,000 miles
*Gone, but still in the family*
98 Gr. Voyager 200,000 miles (the last 100K thanks to these forums)
May she R.I.P.
***89 Mazda 929 180,612 miles***
Old 09-05-2008, 08:38 PM
Mbriggs Mbriggs is offline
Hi,
I had this same exact problem last weekend. Can you please tell me where I should look to see if I have a burned out connnector?
Thanks!!
Old 09-06-2008, 01:12 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Originally Posted by Mbriggs
Hi,
Thanks!!
Read post 3 in this thread.
Old 09-06-2008, 01:02 PM
Thanks! I didn't know if it was a connector to the fan motors.
What a PITA location for the relay! Went at it from the bottom and lost some skin off my wrists and fingers but finally got it out. Wires were fine so just needed the $50 relay. Works fine now.
This site rocks! (and saves me lots of $)
Old 09-06-2008, 01:12 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
From what I've read, you did it the hard way. Most go from above. The main thing is you fixed it. I should say, you fixed it and kept a bunch o bucks in your wallet in the process. Great job!
Old 09-11-2008, 03:57 PM
Robertmchenry Robertmchenry is offline
DO NOT replace that fan realy with a standard relay, your computer will flip out! Purchase the relay from the dealer!
My connector burned out but I was able to get a connector/relay from a salvage yard.
Old 09-11-2008, 04:08 PM
I paid $49.99 for mine from Advance Auto and it's working fine!
Old 09-12-2008, 10:07 AM
Apparently the ECM monitors the fan relay. When my relay failed the ECM threw en error & the check engine light came on. I did a code read & that's when I relized that the fan relay was the culprite.
If you replace the fan relay with a standard relay the ECM will not understand what's going on & will continually throw error codes.
Old 09-12-2008, 11:37 AM
On my van, only the "Service Needed Soon" light came on and it turned off when I replaced relay with the cheap one.
Old 09-12-2008, 11:57 AM
What are you referring to when you state "The cheap one"??? Is it a plug & play reley (replaces OEM) or did you replace the whole plug/relay with a standard relay???
Old 09-12-2008, 01:24 PM
The plug-in relay only
Old 09-12-2008, 02:50 PM
Cool
One lousey place to place a relay eh? Now, I just have to figure out my wiper issue before I have it inspected in November.
