Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 08-23-2008, 09:41 AM
jeffbazell jeffbazell is offline
2006 Rough idle, awful mpg, no codes
32k miles, all new filters, cleaned o2 sensor at air intake. Runs rough, best mileage I can get is 24hwy. Sound normal to you? My '96 TC got 18/30, engine ran so smooth couldn't tell it was on! That was with 114k!!!!!
Old 08-23-2008, 11:09 PM
hottwheelin hottwheelin is offline
Re: 2006 Rough idle, awful mpg, no codes
I just did a tune-up (first plug and boot change) on my '03 with 165,000 and my Highway milage is close to 27 with combined at 24. Not sure what could be causing the rough idle with only 32K on it. You should be getting better than 24 mpg. I use mid-grade gas because I found that regular gave me a rough idle and bad mpg's even though the owners manual calls for 87 octane. Stay away from the super as my mechanic (lead mechanic of a Lincoln dealership) told me that it will trigger premature "check engine" light. Hope this is of any help and good luck!!
Old 08-27-2008, 10:33 AM
danielsatur danielsatur is offline
It could be the MAF sensor,the Air is measured going to the Intake.
If the data is wrong going to the PCU,your engine will not respond the
way its suppose to.
MCGIVER
Old 08-27-2008, 09:57 PM
Kitt1993's Avatar
Kitt1993 Kitt1993 is offline
Yea but a bad MAF will throw a code/light.
Nick names for my Car....
Abe Lincoln, opcorn:
The President,
Lucky Number 5
Old 08-28-2008, 08:28 PM
YEA!
If hard at Fault, it will throw a code.
However a slow reactive MAF sensor will give you poor performance without a DTC.
MCGIVER
Old 10-03-2008, 07:03 PM
wafrederick wafrederick is offline
Banned
It could be the IAC motor too and Ford products do have problems with them.Unbolt it with it plugged in,have someone turn the key on and off.It should move when the key is on and go back with the key off.
Old 10-25-2008, 08:28 AM
p71 JD's Avatar
p71 JD p71 JD is offline
Check that your injectors are tight,I had a loose one and that gave me rough idle,running like crap!!
99 lincoln Town Car Executive
Old 11-11-2008, 03:57 PM
Psman32@af Psman32@af is offline
Send a message via AIM to Psman32@af Send a message via Yahoo to Psman32@af
There are no IAC motors on 05+ panther chassis vehicles. 05+ panthers are electronic throttle control.
2005 Mercury Grand Marquis. 230 WHP 249 ft-lbs as measured by a mustang dyno.
Old 11-23-2008, 11:23 PM
V8-dreams V8-dreams is offline
HY ,
I'm that guy with the 2005 LTC and the same problem.
Did u find now the problem with ur car ?
Please give me a tipp
THX Oliver
