Go Back   Automotive Forums Car Chat > Honda > Integra
Old 03-12-2003, 05:27 PM
casperGSR's Avatar
casperGSR casperGSR is offline
Send a message via AIM to casperGSR
Performance front axles
I'm doing a buildup on my motor so i can crank up my boost some more... I already have most of what I need, the only thing that I'm in the need of some help is having to do with the front axles... I plan on being able to push well into the mid 300 whp range, the only problem with that is my stock front axles will most likely break in two... so I'm looking for performance front axles, the only place I've been able to find that I've done some research on and appears to put out out quality stuff is www.driveshaftshop.com... any help is greatly appreciated. thanx.
Built and boosted...
"I feel the need.... the need for speed!"
http://www.automotiveforums.com/img.php?313283teggie2.JPG
Old 03-13-2003, 11:53 AM
GSR GSR is offline
Send a message via AIM to GSR
try raxles.com
however, I wouldn't concentrate on axles right now...
what/who's differential are you currently using? tires? traction bars? suspension? fuel managment?
If your axles are worn and clicking just go to a nearby auto parts store (ie napa) and buy a pair of lifetime warranty axles. they shuld cost no more than $90 a piece. From what i have seen they last quite awhile so unless youre breaking axles between runs, dont worry about them.
looking for a 95+ 240sx in/near D F Dub area
Old 03-13-2003, 03:30 PM
casperGSR's Avatar
the only reason I'm looking to get new performance axles is because I'm gonna be pushin 12 or 13 lbs of boost daily and then 17 or 18 or so at the track... Stock axles won't last too long pushing this much boost.
Old 03-14-2003, 09:45 AM
GSR GSR is offline
neither will your stock sleeves
Old 03-16-2003, 02:57 PM
casperGSR's Avatar
being resleeved this week...
Old 03-16-2003, 04:16 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Dang!!! Post your times when you get um. :toothless
