Old 08-23-2008, 01:45 AM
Axelthered05's Avatar
Axelthered05 Axelthered05 is offline
91 civic distributor swap
Is it posible to swap in a 92 honda civic distributor in to a 91 honda civic dx d15b2? any information would be helpfull
Joshua Cranfill
Old 08-23-2008, 01:53 AM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: 91 civic distributor swap
You would have to convert the whole car to obd1, and multiport fuel injection.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 08-23-2008, 02:50 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Why are you needing to do this? Bad igniter, coil, what? You might be able to swap the parts you need around, but you can't just plug and play the whole distributor.
As Frodo mentioned, it would require doing a MPFI conversion and OBD1 conversion to use it.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-23-2008, 09:17 AM
Its simple, I am a nut for customizing and want to put this part on http://www.amazon.com/Mr-Gasket-1107...031668&sr=1-24 but it will only fit on a 92+ Distributor (even thow the website says it will fit, it does not -.-)
Joshua Cranfill
Old 08-23-2008, 01:01 PM
Tony's Avatar
TLD Member #1
Well Mr. Nut for customization....in simple terms, no it will not work, and sorry I won't help you on making it work. I'm a big Function over form guy, so I don't see the point. Maybe someone else will be willing to give you some advice on it.
Tony
Old 08-23-2008, 02:53 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
wait... you can't use an OBD-1 cap on a OBD-0 dizzy? I always thought you could...
So.. customization guy... try customizing it... I mean, that's what you do, isn't it?... MAKE it work.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 09-16-2008, 01:50 AM
wizbang121 wizbang121 is offline
LOOK , it WILL NOT WORK !!!!
Old 09-21-2008, 05:24 PM
well i dont know how to explain it but i figured out how to put the 92 civic distributor cap on a 91 civic without mesing with the wireing, Will keep you all posted on what happens
Joshua Cranfill
Old 09-21-2008, 08:07 PM
don't explain it.. just take a pic.
I could have thought of 13 ways to do it. but frankly, I didn't, since none of them would have improved performance of the vehicle one bit, and as far as I can tell, wouldn't have improved the aesthetic value either.
Old 09-21-2008, 11:35 PM
FrodoGT's Avatar
If it wasn't an obvious solution from the start..or required cutting/glue/anything then you went way wrong. Destroying any aesthetic gain and possibly losing performance to meet the initial idea that it would be cool to have a clear distributor cap.
Current project:
Rio Red 91 hatch.
Old 09-21-2008, 11:38 PM
Thing about this: I"m pretty sure most, if not all honda 4 cyl dizzy caps are interchangeable... I'm kinda hoping for the sake of the OP that I'm wrong about this.
Old 09-21-2008, 11:47 PM
Scrapper Scrapper is offline
AF Premium User
i agree i would use the same dist. your using now. if those plug ins arent right you maybe looking for a another computer and who no's what else you burn up.
