Old 08-22-2008, 09:17 PM
North Coast Hotrod North Coast Hotrod is offline
Disable Air bags
How do I disable the Air bags on a 2001 Taurus? I am running the car in a Demolition Derby and I need to disable the Air bags. Also ... What is the fuse number for the Power Windows? The car was hit in the rear end....so were are going to let it go out with style.....
Thanks
Old 08-23-2008, 02:53 AM
yotermanic yotermanic is offline
Re: Disable Air bags
I would pull the fuse, it's the quickest way to make sure they don't pop on ya. Have fun!
Old 08-23-2008, 11:32 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
For the demo derby, are you planning to bypass the fuel pump inertia switch? One hit and that will probably kill the engine on you.
-Rod
Old 08-27-2008, 02:30 AM
tripletdaddy tripletdaddy is offline
You may want to also bypass the nss or trs wires that control starting in p and n so you can start it in any gear. At least that's what many do our way.
Old 08-27-2008, 02:32 AM
Maybe if you can safely remove the airbag components without damaging them, you could sell them. Unfortunately, you almost need someone to tell you how to take out the dash bag as it isn't obvious on purpose.
