Go Back   Automotive Forums Car Chat > Geo > Tracker
Old 08-22-2008, 09:05 PM
benissimo benissimo is offline
1996 Geo Tracker Ignition Failure
CAR DIES INTERMITANTLY, WHEN IGNITION CUTS OFF
REPLACED CRANK POSITION SENSOR
CHANGED TO A REBUILT DISTRIBUTOR
REMOVED STUFFED CATALITIC CONVERTOR
TO NO AVAIL
MUST BE 1 OF THE 4 SENSORS (OXYGEN, CAM, CRANK or THROTLE SENSORS)
HOW DO I KNOW WHICH OF THE ABOVE 4 SENSORS IS BAD???
I'M IN MEXICO, WITH NO CHEVY SERVICE FOR THIS CAR AVAILABLE
Old 08-23-2008, 05:25 PM
farmerfelts farmerfelts is offline
Re: 1996 Geo Tracker Ignition Failure
After your car stops running, will it start again after sitting for a while? If so, sounds like an in line fuel filter needs to be changed. Hope you find a solution to your problem soon mi amigo.
