Old 08-22-2008, 08:10 PM
C man C man is offline
The Great Debate
I change my oil today and I have to add to the debate of how much oil the 3800 takes. A lot people and sources say 4.5qt. I say 5qt and my owners manual says the same thing. When I changed my oil I put 1 gallon (qt) of oil in first turned the car on to get the oil circulating and then a turned it off and let it sit for a while. Went and read the oil dipstick and it was under the add mark. So I added qt of oil and it filled it up all the way but not past the cross hatches. Maybe the changed some things. I do have one of the few 3800's that burns oil though.
95' PARK AVENUE 168,000 MILES
Warning : Listen at your own discretion
Old 08-22-2008, 08:41 PM
Re: The Great Debate
Here's what it says in my manual
Old 08-23-2008, 08:46 AM
Sweepspear's Avatar
Sweepspear Sweepspear is offline
5 Qts. and my level is dead on the full mark.
Dale
Current Buicks..1996 Riviera. / 1992 Park Ave. /
1970 Riviera (2nd one)
Past Buicks. '66 Riviera / '70 Riviera / '90 Riviera / '72 Skylark / '72 LeSabre / '72 Electra / '96 LeSabre
Old 08-23-2008, 10:38 AM
Blue Bowtie's Avatar
Registered Offender
What debate? As always, fill it until the dipstick is satisfied.
Old 08-23-2008, 11:30 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Originally Posted by Blue Bowtie
What debate?
I don't care what GM car it is with the L36 or L67 SII 3800 engines but 5 quarts is too much and it is over the max mark/lines on the dipstick meaning it is overfilled. Sounds like someone may need glasses.
The most important part if there is any debate is the oil filter. I no longer recommend or will use AC Delco PF47 oil filters. Poorly designed anti-drainback valves. Now made by Champion for Delco based on the crappy Ecore design. Stick with Mobil 1 or WIX brands. Mobil 1 oil filters are made by Champion too but based on a performance design.
BTW - Does this PA have the VIN "L" or VIN "K" 3800 engine?
Timeslip 08/12/06
AF Community Guidelines
Old 08-23-2008, 01:37 PM
Jrs3800 Jrs3800 is offline
I use and have always used 5 Quarts, at the same time I use the PF52 Equivalent Filter which is a hair longer than the PF47... So 5 quarts is what I fill with on all of my 3800's due to the filter size..
With most all 3800's over the last 20+ years you will be most likely to use 4.5 Quarts... Fill it to the top of the cross hatch as stated...
C Man
Don't feel bad... I have had 2 L36's that use a little bit of oil... And one that never used any at all...
Old 08-23-2008, 04:03 PM
it's a vin K and I use a Pureolator filter. The emission people made me mad today. The said my car had blue smoke when I pushed the gas pedal. Passed inspection with flying colors since I had the car and to make it worse I slammed on the gas pedal harder than I did when I was at the inspection place and no smoke. And I sat in the line for and hour and a half.
Old 08-24-2008, 12:36 PM
Ahhh... Mine used to do that too a little... And only once in a very blue moon.. I almost think the 96-96 L36 May have been a tad looser than the 97-05 series II engines..
My Cousins 95 Burned a little oil like mine did.. The Current 96 engine Burns a little as well... But the 99 Motor I had didn't burn a drop...
Mine made it to the 161k mark... You should get further than I ever did..lol
Old 08-24-2008, 02:07 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
How long did the engine idle while you were sitting in the line?
Old 08-24-2008, 02:11 PM
The engine was idle in the line for 1.5 hours. I probably should have revved it a little to clear out any oil seeping past the valve seals. Usually I only have to wait in the inspection lane for about 15 minutes but I went when it was busy instead of the morning like I usally do.
Old 08-24-2008, 03:32 PM
HotZ28's Avatar
AF Moderator Elite
You hit the nail on the head (first swing)!
Old 08-24-2008, 04:52 PM
Sweepspear's Avatar
I won't use AC Delco filters anymore either after an incident I had 3 years ago.
I changed my oil and filter as usual, and found my oil pressure was all over the map! Never steady.
I took the AC filter I had installed off and compared it to the old one I took off and the new one looked to be of lesser quality.
I put the old one back on until I could resolve the issue.
I contacted AC Delco about it because I thought it may be a counterfeit part.
Turns out the old filter which seemed to be of better quality was a Mexican made filter, and the new filter was made in the USA by Delphi.
I would post pics or a link to my thread on v8 buick.com where I posted photos of both filters and the reply I received from AC Delco, but not sure if any linking to photos or other boards is allowed here.
If it is ok, I will post them.
I only go with NAPA Gold filters now which are made by WIX.
Dale
Old 08-24-2008, 05:36 PM
In Buying the AC Delco Filters, from what I understand the PF47 with a sticker is the real deal... The PF47 with the Painted on label is not the one used BY the dealerships, and sold at auto parts stores... I have to date had 0 issues with the Sticker PF47 Filters..
Bob the 1995 Park Avenue has the L36 Vin K in it..
Its funny tho, at the same mileage Cman has mine started to do the little smoke thin once in a while on a warm start...
I think I had piston and ring issues tho.. And had developed more and more piston slap towards the end of my engines life...
Old 08-24-2008, 07:44 PM
HotZ28's Avatar
AF Moderator Elite
In order to help clarify the quote above for other members; the 1995 PA came equipped with both the L67 Vin-I, and the VIN K, depending on which option you have. The Ultra had only the Vin-I the Series I in 1995. C man, you have a valve stem seal problem!
BTW, Wix filters are made by Affinia Group, which continues to outsource production to China, India & Mexico! Good luck, especially if you get one “Huncho in Mexico”!
Old 08-24-2008, 08:12 PM
I Kinda figured that when I first got the car because I did research and found out that the seals for the 94-95 years were prone to faliure. Plus the fact that I burn a quart of oil ever 1200-1400 miles with no oil leakage on the ground drew me to this conclusion. My question is how hard of a job is putting in new seals and is it worth it. I kinda want to do it but don't know if it beyond my level or worth it or if I will do more damage than harm.
