Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 08-22-2008, 12:01 PM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Oil Pressure Light
Ok so I've searched everywhere on here and can't find anything...Last night on the way back home from Pittsburgh, I noticed that my oil pressure light started blinking super fast. It doesn't come on and stay on, just blinks real fast. So I pulled over asap to find out what was going on. I checked the oil, it was full and clean. Nothing was leaking. Got back in the car, and the oil pressure seems normal at idle and throughout rpm's (have aftermarket gauge). WTF is goin' on here? Also, there are no odd sounds or noises from the engine. It sounds healthy and still runs like brand new.
Old 08-22-2008, 01:25 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: Oil Pressure Light
Sounds like either a loose connection or sensor is going bad. If the aftermarket itself is working fine, then trust that one. I'm kinda surprised you still have the stocker in there.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 08-24-2008, 01:37 AM
scottsee scottsee is offline
Send a message via AIM to scottsee
The oils pressure sending unit that's connected to the oil filter housing has a small wire attatched to it. That's the light to your dash, check the connection and/or add a t-fitting and install an electric oil pressure sending unit so you can monitor your oil pressure.
DSM geek
Old 08-28-2008, 04:38 PM
Yeah not too long after posting this I figured out what it was. It was the wire for the dash light, it somehow came disconnected and was smacking off of my lower intercooler pipe. Forgot to jump back on here and tell you guys. Easy fix.
Old 08-28-2008, 08:22 PM
rock0134 rock0134 is offline
Send a message via AIM to rock0134 Send a message via Yahoo to rock0134
I've got a quick question. I have the glowshift electric oil pressure sensor and gauge that I just hooked up a few months ago. At idle it sits around 0psi? And it increases steadily with the increase in rpm. Does that sound right?
SOLD
'97 GSX
EvoIII 16g, FMIC shortroute piping, FIC 850's, DSMLink V2.5, 3" turboback, mbc, Walbro 190 rewired, autometer boost gauge, Tokico shocks/springs -2", Motegi MR7 18" hyper black wheels
'05 blacked out f150 FX4
Old 08-28-2008, 09:39 PM
david-b's Avatar
Dave is THAT guy
Never had that happen on mine. Sounds like maybe a loose connection also there.
75 Monte Carlo
Old 08-28-2008, 10:35 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Is it a full or short sweep electric gauge. Mine oil pressure is full sweep and has 10psi,20psi,etc. Mine sits around 10-20psi at idle. My buddy has a short sweep and it only has 25psi,50psi,etc. And his appears to sit around 0. When you turn the car off the gauge goes down more so the oil pressure really isin't at 0 it just looks like it. So this could be the problem your having.
If you really want to test it out get a cheap mech. pressure gauge from lowes and connect it up just to see what your getting at idle.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
