Old 08-22-2008, 09:24 AM
BeZerK2112's Avatar
BeZerK2112 BeZerK2112 is offline
380HP Isn't Enough...
Name that part!
Replaced my oil pan crank gaskets last night. Found this in the oil pan. Anyone know what it is? I sure do!
WHAT KEEP IT STOCK! Well that takes the fun out of it.
[center]
99 Maxima - View the Project at CarDomain
Old 08-22-2008, 10:46 AM
redimp2000's Avatar
redimp2000 redimp2000 is offline
Re: Name that part!
Looks like an engine bearing to me.
opcorn:
Just sittin' here watchin' the world go by
Old 08-22-2008, 10:47 AM
BeZerK2112's Avatar
Re: Name that part!
NOPE! Try again!
[center]
Old 08-22-2008, 03:55 PM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
Re: Name that part!
Is it part of the bottom half of the connecting rod?
Old 08-22-2008, 08:56 PM
BeZerK2112's Avatar
Re: Name that part!
No. First guess was closer.
[center]
Old 08-23-2008, 08:59 AM
freakray freakray is offline
AF Modelrater
Re: Name that part!
crankshaft bearing
rod bearing
without anything in the photo for scale, it's not very easy to nail down which of the bottom end bearings it is.
AF User Guidelines
Old 08-23-2008, 07:49 PM
72chevelleOhio 72chevelleOhio is offline
Re: Name that part!
The bearing out of that wasted turbo....?
Old 08-23-2008, 08:07 PM
AF Modelrater
Re: Name that part!
Turbo would typically be a ball bearing - that's a bronze bushing in the photo.
For a turbo's bearing to end up in his oil pan, he's got much bigger problems.
AF User Guidelines
Old 08-23-2008, 09:29 PM
stoned_pimp420 stoned_pimp420 is offline
Send a message via Yahoo to stoned_pimp420
Re: Name that part!
valve spring half collets (valve retaining half thingys that generally put your eye out while trying to remove them) I have a creepy feeling of a dropped valve!
I'm not sure what the other half thing is, not yet anyways I didn't put much thought into this thread to be honest.
I'm back after a long mental evaluation and heavy medication!
If you can't be a good example, you can always be a horrible warning!
Old 08-24-2008, 09:02 AM
BeZerK2112's Avatar
Re: Name that part!
Yep! It's an oil float bearing from the broken turbo!
The bearing fell apart. The parts were small enough to travel through the oil return line and end up the bottom of the oil pan.
Thanks for playing!
[center]
Old 08-25-2008, 11:57 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Name that part!
Oil return goes straight from the turbo to the pan, at least that's what he told me. Also, you'd be surprised at how many cars use sleeve bearing in the turbos. My GTC has BB turbo but the Stealth has sleeves.
