Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Interiors
Old 08-21-2008, 05:36 PM
vzfox vzfox is offline
Cool dome light KA-NUM-DRUM
Ok....here's a tricky one, tell me if you've heard it before....
No dome lights lighting up overhead....checked both bulbs, good new bulbs....put a multimeter to each end of the bulb connectors, 12V.....put the same multimeter on each end of the bulb itself, 12V....but no light.
If the bulb is "flowing" 12V thru it, then it has no choice but to emit light.....right or wrong?
KA-NUM-DRUM....
1995 Eclipse RS
Old 08-22-2008, 02:04 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: dome light KA-NUM-DRUM
Touching the end terminals with a meter is only going to tell you if its getting power, touch the + terminal to the negative side of the light and then ground the negative and this will tell you if power is making it through the bulb. Find out which end is positive with the light removed and test the opposite side of the bulb.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 08-23-2008, 08:50 AM
Thumbs up Re: dome light KA-NUM-DRUM
You were right....even though the bulbs arent "burnt out", the voltage wasnt making it thru the bulbs. I bought some new ones again and they lit right up. But still, if the other ones werent burnt out why wasnt the voltage making it thru the bulb?
Still a KA-NUM-DRUM.....but the issue is resolved. thanx.
Old 08-24-2008, 03:38 PM
Holset powered 420a
The filament was broken inside the bulb or somehow disconnected.
98 Eclipse GS Turbo
2001 BMW 325i - DD
