Go Back   Automotive Forums Car Chat > Ford > Aerostar
Old 08-21-2008, 03:58 PM
jocelyn martel jocelyn martel is offline
heater core test
How to test if the heater core is good on a ford Aerostar 97 ?
Old 08-21-2008, 05:38 PM
Davescort97 Davescort97 is offline
Escort guy
Re: Coolant Air pocket
On my 97 Escort there is no bleed valve for air pockets. After flushing it, I ran it on water with the cap off and it got rid of the air pocket through the filler neck on the radiator. Then I drained half the water out and filled it with anti-freeze. Does anyone know about air pockets and a better way to do this?
Old 08-21-2008, 07:21 PM
rhandwor rhandwor is offline
I've used my pressure tester and put a few psi on the system this seems to help somewhat.
I've also jacked up the front of the car and this seemed to help.
Old 01-02-2009, 09:08 PM
WillieEverlearn WillieEverlearn is offline
Pull off the supply-side heater hose while the vehicle is running at normal temperature and the heater set to heating, to let the air out.
Willie
