Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 08-21-2008, 01:25 PM
ulremember ulremember is offline
Emission HELP Please!
Hello to all!
I have a serious problem with a 95 Tahoe. I have changed the EGR valve and the O2 sensor. With each change the results are worse when having it checked at our local smog station. Here is what I have:
HC (PPM) max allowed 83, measured at 200 @ 15 MPH.
NO (PPM) Max allowed 477. Measured 1621 ppm @ 15 mph
HC (PPM) max allowed 48ppm. Measured 190ppm @ 25 mph
NO (PPM) max allowed 730ppm. Measured 1516ppm @ 25mph.
I have no clue why it has gotten worse after changing the key sensors and parts. Could it be the CAT(s)?
Any help or information is appreciated by myslef and brother in law. (his truck)
Blessings to all in attendance!
Chuck aka ulremember
Thanks to all!
ulremember aka Chuck Jr.
Old 08-22-2008, 11:54 AM
Re: Emission HELP Please!
If this helps, the truck does not smoke. It actually runs very good!
It is not a "smoker"
Blessings to all
Thanks to all!
Old 08-22-2008, 03:31 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Go for a good old fashion basic tune up.
If that does not do it get out the fuel pressure gauge a nd a engine capable scanner.
Get codes and rear out data and complete fuel pressure check.
Post back codes and fuel pressure and out of spec data /sensor reading.
MT
MT
Old 08-22-2008, 03:41 PM
spytearbite spytearbite is offline
Banned
Pull All plugs and do not mix them up. Which one is the most sooty? Could be an injector hanging up in that cylinder giving off that much NO/HC.
Air cleaner clean/dirty? Try with zero air cleaner installed. Let the air unrestricted so there is more air than fuel gulping.
Old 08-22-2008, 05:06 PM
j cAT j cAT is offline
Originally Posted by ulremember
Hello to all!
MAP sensor...check the voltage output at idle should be around 1.5volts dc. also make sure PCV is replaced and hoses to it are in excellent shape...
If the cat was bad it would not cause those very high readings..
Old 08-23-2008, 11:33 AM
Thank yous to all that replied. Will get on it! I forgot about the MAP. Worked on a car a long time ago, it was the MAP and BARO!
Blessings to all
Thanks to all!
Old 09-08-2008, 12:43 PM
One question. How do I check the MAP sensor with it on the car. Do I go to ground with my meter, or do I jump across two of the three leads?
Thank you in advance!
I tried from ground to each wire. The highest voltage I got was 1.2 I think on the green lead in the middle
Thanks to all!
Old 09-08-2008, 03:41 PM
the wires should be ground,5volts d.c. , and the MAP output...3 wires correct... a reading of 1.2 volts dc sounds good..remove the MAP and make sure that the intake rubber gasket is in good shape...
Old 09-08-2008, 04:10 PM
Hello to all!
since the MAP appears to read in the normal area now you must check that the EGR passageways are clear ....many times I have had to do this on my now retired vehicles...
usually the intake passageway gets plugged with carbon....as you probably know exhaust gas is sent to the intake manifold by the EGR valve...If this is not done the combuston chambers will get too hot and this then causes high N.O. readings as well as pinging....pre-ignition...
let me know what you found or if you have more questions..
Old 09-08-2008, 06:08 PM
Thank s j cAT! I really appreciate this. SMOG PROS were gonna charge him 700 dollars for the repairs. Get this, NO REPORT THAT THEY CHECK ANYTHING> Charged him 90 dollars and RECOMMENDED the fix of: CAT EGR (new) (checked with vacuum pump. instructions say do not test with), and possible theromostat missing or stuck open (OH YEAH, they said it would not get to operating temp so they blocked the radiator) Low coolant I found but I know that did not cause it. Sorry to run on, but I thought about the temp. Now back to the blockage. I will check. I put the egr on and did not notice the common build. But I am thinking the intake area to the heads? Maybe you think let me know and thank you VERY much!
Blessings
Thanks to all!
Old 09-08-2008, 07:09 PM
Blessings
a quick test is to manually force open the EGR with your fingers with engine at idle this should cause the engine to stall...this will indicate if passageways are blocked..
another test is place a vacuum guage in line of the EGR control vacuum line and with a long enough hose take a ride you should see 7-10 inches of vacuum when increasing spend..this ensures that there is vacuum to open the EGR...
this will give you help as to whats bad..
Old 09-12-2008, 12:45 PM
Hello! j cAT, I just opened the egr with finger, and it stumbled pretty good. I also hooked up the vacuum line straight to the egr. It does pull it open a bit. I also hooked it back up to the control solenoid, and it open slightly when I raise the r's. Could it be the temp sending unit? I otice that the te,p gauge does not show that the temp of the engine is not as hot as it should be. I would say that it is showing about 152 degrees ( line on gauge between 100 and 210).
Well I want to thank everyone that has replied so far, and I hope that I get more sugesstions.
Blessings to all
Thanks to all!
Old 09-12-2008, 06:12 PM
Blessings to all
that engine temp sender could very well be the problem as the engine management thinks the engine is still warming up and not providing the correct idle air mixtures too rich...and it can also prevent EGR operation... ECT sender unit replace it..should be 190deg f
Old 09-14-2008, 07:20 PM
Bless you! I will have brother in law invest in the ECT. It is the one on the side of the head? correct?
Blessings
Thanks to all!
Old 09-15-2008, 09:34 AM
Blessings
the ECT on the driverside of engine near #1 plug is the computer ect....on a 5.3l engine ....the 5.7l engine it is near the thermostat..the resistance at 75-80deg should be around 2800ohms and at operating temp 275 ohms...
