Go Back   Automotive Forums Car Chat > Toyota > Tundra
Old 08-20-2008, 10:54 AM
Mtnchev Mtnchev is offline
Cool CV Boots
04 Tundra Double Cab CV boots throw grease after a 3" leveling kit install. Have had boots replaced and still leak. Anyone have any advise?
Old 08-20-2008, 12:01 PM
Scrapper Scrapper is offline
AF Premium User
Re: CV Boots
you never had a quick boots put on did you? you do not want to use those unless it's a have to until you get home.another thing is check see if both clamps are tight on both ends if there tight i say a hole or to much grease in them and if you go to replace them get the hole half shaft. use to the outer cv joint was just as much as a hole half shaft so if you go to replace them get the whole half shaft and put it in and it's not that hard.
