Abs Pulsing At Slow Speed
My 2001 2500HD is acting like it is sliding on ice. My abs pulses at slow gradual stops. I was told to clean the ABS sensors but I am not sure how to get to them I assume the front wheels but where do I find the sensors and how do I get to them???
Any help would be appeciated. Gat |
Re: Abs Pulsing At Slow Speed
this should help. you have bleeding/diagnostic/sensor locations:
http://www.autozone.com/shopping/rep...00c152801b4a86 |
first see if you are under the recall....NHTSA has determined that your vehicle has a defect....call dealer with vin #....they will let you know... second before you bring to dealer make sure that the front rotors will come off....many have had to pay 1200.oo for this FREE recall....just another way to scam you....so you have been warned... the sensors are under the rotors and rust from the cheap metal they used forces the sensors out of position also you may have a bad wheel bearing ...this is a common problem... |
Nothing there to help but thanks, I know it's not a bleeding issue.
One of your front wheel speed sensors is off, you need to find somebody with a graphing scanner to figure out which one. Dont go by the ABS codes alone b/c they are not always right. What you are looking for is when you come to a stop there will be 3 sensors(RF, LF, and rear) that will decelerate and probably around 5mph one of the will jump to 0mph when the other 2 are still at 5, thats the bad sensor.
ASE Master Certified before the age of 20 Current Cars: 2001 Chevy Silverado 1500 Z71 5.3L 1996 Acura Integra LS B18 1.8L Past Cars: 1990 Buick Estate Wagon 5.0L 1987 Chevy S10 2.5L Tec Four 1995 Pontiac Grand Am 2.3 Quad 4 1996 Jeep Grand Cherokee Limited 5.2L AWD 1991 Ford Tempo L 2.3L 1992 Buick LeSabre 3.8L 1997 Buick Century 3.1L 1996 Lumina APV GT 3.4L 2006 Ford Escape 3.0L XLT |
I apologize for my lack of patience and not looking far enough into the link sent by UKRKOZ and also that all of you for help. I am going to try and find some phots of this stuff to help as well. GAT |
Do you have warped disc? An out of true or say there is a high-spot on the disc run-out? Then, there is your pulse at slow speed, not an abs problem, but more disc out of true is push the piston back into the caliper on the high spot; is push your pedal back and forth on the slow; you feeling each 360 degree turn on the disc.
Did the new discs come with tone rings? Or say, did they reinstall the matching OEM with some sort of 'ping' signal to the abs wheel pickup? I would assume no ring tone, you would set an abs code?
Any way there is someone with another truck similar or we talking this just started with the new parts? |
Right. Won't take long you spin the disc and hold a pencil to the disc then spin it. You see a high spot? You have junk that lasted a few months? And the truck is how old with OEM> Before the disc swap?
