Go Back   Automotive Forums Car Chat > BMW > 5 Series
Old 08-19-2008, 11:09 PM
enidan enidan is offline
1991 BMW 525i Electrical Problem
Recently, the cars electrical system shut down. The central locking system, the windows, seat adjustments, interior lights and the radio quit operating. The A/C, outside mirrors, driving lights & ignition remained operative.
Removing the electrical modules in the engine compartment & re-seating them reset the system. Then the same issue recurred. Re-seating the modules did not resolve this the second time. Only when the modules under the rear seat were removed and re-installed did the systems start again.
Any idea as to which module is defective?
Old 05-08-2010, 04:50 PM
jorgescar69 jorgescar69 is offline
Re: 1991 BMW 525i Electrical Problem
check your and replace the relay under the back seat
Old 07-14-2010, 05:35 PM
3100 3100 is offline
Banned
-those connectors that you disconnected could be dirty or loose
Old 09-26-2010, 01:49 AM
bob1962 bob1962 is offline
i recently had a simular problem with my wipers, seats,windows and doorlocks all going out on my 1990 bmw 525i E34....i checc
ked everything and finally checked a small rubber compartment right behind the battery where the positive cable leads into it....theres a thin metal piece of connector between the cables check it real good..coud be cracked or broke.....solved all my problems at once
