Old 08-19-2008, 10:20 PM
Jimmmy Jimmmy is offline
Front end vibration issue with speed
I have a 2000 blazer (4X4) and i have just recently noticed that above 30 mph the front end starts to vibrate with speed. The faster i go, the more it vibrates. I did noticed that if i turn to the right while driving, the vibration goes away, but comes back as soon as i go straight again. It feels almost as if the 4 wheel drive is engaged, but I'm pretty sure its not.
I'm thinking its either the tires are not balanced or the front drive shaft u-joints?
Is the front drive shaft always engaged, or only when the 4x4 is on? I have the "trail blazer" edition so it has the auto 4x4 function if that matters.
Any suggestions guys?
Thanks
Old 08-20-2008, 11:13 PM
blazes9395's Avatar
blazes9395 blazes9395 is offline
Newbie mod
Re: Front end vibration issue with speed
Could be a few things. Could be a tire issue, a wheel bearing issue, alignment issue, if you tires are not pointing forward, or parallel to each other, they could cause vibration. It could be a front axle problem too, but I doubt it, its possible though. The auto 4x4 in your truck has a vacuum solonoid under the hood, at the back on the firewall, kind of in the center of the firewall. These solonoids fail and can cause front axle engagment issues, something worth looking at to make sure it works properly at least. If the solonoids sticks, it can casue the axle to be engaged all the time when it should not be (2wd button). The front driveshaft should not be engaged when in 2wd.
Does the vibration go away when the truck is in 4wd?, or does it show up in all ranges?
Old 08-31-2008, 12:10 AM
cmoney2 cmoney2 is offline
loose lug nuts, and or outer tie rod ends
Old 09-16-2008, 02:17 AM
gatoratoy227 gatoratoy227 is offline
worn ball joints are another issue that could be causing the vibration
NO! ,we can't stop here, this is bat country. Raoul Duke
