Go Back   Automotive Forums Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 08-19-2008, 05:03 PM
chitownxt chitownxt is offline
Front Right squeals in reverse
Bought a 2007 SE with about 16,000 miles. When I back up slowly, I hear a few clicks and then a squeal, similar to really worn brakes. This happens only in reverse and WITHOUT my foot on the brake. Dealer says this is the brake sensor's early warning that indicates I need new pads. They claim with more wear, it would happen in drive as well. Is this true? Seems a bit early for brakes and is a stange way to warn of wear on the pads. Their "suggestion" is new pads, a sensor, and re-surface rotors. Don't really trust them.
Any thoughts?
Old 09-03-2008, 08:29 PM
jmak jmak is offline
Re: Front Right squeals in reverse
Brake material is very easy to see . Also easy to tell if it is gone and in need of changing. 16,000 miles is very low mileage to need new brake pads but I don't know how you drive. I have 60,000 miles on my Xterra and 6 years of driving it in the city and I went through my first set. I bought new rotors and brake pads and it was cheaper than what the dealership would have charged me. If you don't trust one dealership try another . My local Nissan dealership is terrible so I drive 60 miles to another one and get much better service.
Old 09-04-2008, 10:53 AM
RaeRae1's Avatar
RaeRae1 RaeRae1 is offline
Send a message via AIM to RaeRae1
On many cars there is a "sensor" which is simply a piece of metal that will rub the outer rim of the rotor and vibrate to make noise when the brake pads get low. I am pretty sure this is what your mechanic is referring to. I agree that 16,000 miles is low and if it is only one set of pads that is worn out, you may have a caliper that is sticking. I would take of the wheel and check the thickness of the pads on the brakes. Inspect both sides to see if they seem to be wearing even. If not, I would say you have a caliper that is sticking and needs repair or to be replaced.
Blessed are the cracked ones, for they are the ones that let in the light.
Originally Posted by 72chevelleOhio
Your cheer-mobile needs a flat tire.
