Old 08-19-2008, 02:54 PM
beads beads is offline
Tranny fluid specs
What type of fluid does a 1994 Taurus AXOD tranny call for?
Thanks in advance.
Old 08-19-2008, 06:42 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: Tranny fluid specs
The 1994 used Ford's Type F. You can use Mercon or Mercon IV in the transaxle. If you change all the fluid, you can use Mercon V. So Type F will work just fine.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-19-2008, 08:06 PM
Will DEX/MERC work OK?
Old 08-19-2008, 09:20 PM
MIBPreacher's Avatar
MIBPreacher MIBPreacher is offline
Why is that was you put in it?
Old 08-19-2008, 09:49 PM
Scrapper Scrapper is offline
AF Premium User
i would stick to type f unless you want to switch over everything.
Old 08-20-2008, 06:27 AM
way2old's Avatar
TOKEN HILLBILLY
The DEX/MERC will work fine.
Old 08-20-2008, 07:06 AM
Yes..I replaced the filter and gasket and put DEX/MERC in it..
Old 08-20-2008, 09:54 AM
Will the mixture of the old Type F and the DEX/MERC cause problems?
Old 08-20-2008, 02:57 PM
way2old's Avatar
TOKEN HILLBILLY
Should not be of any concern. Mercon V can be used in place of Type F or Mercon, but you can not use Type F or Mercon in a transmission designed for Mercon V.
Old 08-26-2008, 02:17 PM
Thanks for the replies all. If I wanted to change all of the fluid is that something I can do at home or will I need to take it to a shop that offers a transmission flush? The reason I'm thinking of doing so, is that I was having a problem with some rough shifting previous to changing out 6 QTS. Right after I changed the filter and 6 qts of fluid it was shifting beautifully. The next day when I drove it it was back to shifting hard again. I was thinking maybe a full "flush" would alleviate the problem? Any other ideas would be welcome. I'm hoping this isn't another "known bad transmission" issue I've heard about on these cars.
Thanks in advance.
Old 08-26-2008, 10:43 PM
AF Premium User
did you take magnet and run threw your old tranny fluid to see how many metal shavings was in there? if not go to a well known shop to get it flushed if your going that way.
Old 08-27-2008, 11:00 PM
Willyum Willyum is offline
The Mercon V I've used, Castrol, claims on the bottle that it stops shift "shudders".
Old 08-27-2008, 11:45 PM
AF Premium User
Thumbs up Re: Tranny fluid specs
sorry but i belive in rotela is best for bikes and semis and go along way. on oil any way. tranny fluid mercron or dexstron 3. good luck....
scrapper1
Old 08-28-2008, 07:56 AM
Scrapper, I didn't run the magnet through the oil that I removed, but the magnet was coated with about a 1/16th or 1/8th inches of shavings.
Old 08-28-2008, 01:08 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
If those were fine particles, almost like a sludge, rather than "shavings" that is not abnormal, especially if the fluids rarely changed or if the magnet wasn't cleaned during past services.
-Rod
