Go Back   Automotive Forums Car Chat > Chevrolet > General Discussion
Old 08-19-2008, 02:34 PM
NINFan NINFan is offline
dex cool and corrosion
so my son comes home the other day with steam pouring out from under the hood. ("gee, dad, i didn't notice the guage"). '99 blazer 4X4. V6.
turns out the water pump i put in a few months ago has a pinhole on the pipe where the bypass hose connects. replaced the water pump, all is good. now it sprung a leak in the metal pipe that sits on top of the thermostat housing where the upper radiator hose connects.
is this just coincidence? as i thought about it, i realized that i probably mixed dex cool with glycol-based antifreeze at one point or another in the past history of the car. could it be causing such bad corrosion? i've never seen pinholes in the metal like that. maybe bad rust in the block, but not steel.
btw, the stuff that's in there is the most ungodly looking brown crap i've ever seen. i've 'flushed' it (stuck the hose in the radiator with the engine running) multiple times, but it still runs brown.
any ideas?
Old 08-19-2008, 02:47 PM
maxwedge maxwedge is offline
A990 racer
Re: dex cool and corrosion
At this point you will need a power flush on a coolant flush machine to get the job done, by the sounds of your coolant condition, and even that may not do the job completely, the heater core and radiator may be the next victims.
Old 08-19-2008, 08:48 PM
j cAT j cAT is offline
any ideas?[/quote]
unfortunately for you its all over for that engines coolant system...
mixing and the use of non dexcool in these engines is not recommend by GM the use of non dexcool will cause damage to the coolng system.....
by posting your results of this mixing hopefully others will learn without the pain.......
Old 10-26-2008, 07:31 PM
think i got this. just kept flushing it over the last few weeks. ended up taking the return heater hose off at the firewall and ran it with a hose in the radiator. finally got it cleared out - it's running clear now. gonna let it go for a while and make sure all the gunk is out before i put antifreeze in it. hope that's got it.
Old 10-26-2008, 09:41 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
That is not advisable. The coolant acts as a lubricant to the bearing in the water pump, also straight water pressurized and under heat will corrode (rust) the head gaskets and the freeze plugs - both of which can be a serious (read: expensive) issue to resolve.
Get some coolant in there!
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-26-2008, 10:24 PM
Blue Bowtie's Avatar
Registered Offender
Better yet, I'm not sure about where you are, but it's 27º (Fahrenheit, not Celsius) outside here right now, and pure water is going to get really problematic if you have similar weather.
