Go Back   Automotive Forums Car Chat > Classic Cars
Classic Cars Do you just love the classics?
Old 08-19-2008, 01:46 PM
JCBauer JCBauer is offline
Exclamation ATTENTION GEAR-HEADS...please help!
Hoping you all could help me with a project with a tight turnaround.
I’m looking for insights as to how a do-it-yourselfer might treat his daily driver differently than his project car in terms of motor oil. Will they use the same oil or splurge on a high-performance or synthetic for their project car? Do they let the mileage go a little longer between oil changes on their daily driver?
So, what do you do? Your the expert!
Thanks,
Jared
Old 08-20-2008, 08:30 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: ATTENTION GEAR-HEADS...please help!
Personally I use the same regular oil on my project car for 2 reasons:
1. The project cars are old and relatively primitive, compared to modern cars, so they would benefit less from synthetic or more expensive oils. By 'primitive, I mean the engines run cooler, are more simple, have looser surface clearances and tolerances and fewer moving parts that todays multi valve, DOHC engines which run hot for emissions purposes.
2. I drive my project cars generally less often and more gently that the modern daily driver, so the oil is less stressed.
And yes, I do change the oil in my daily driver less often, based on mileage. This is not because I care about it less, but the fact that it is driven more often and for longer periods of time means there is less opportunity for condensation and other harmful volatile deposits to contaminate the oil and necessitate a change.
