Old 08-19-2008, 01:44 PM
ghalacsy ghalacsy is offline
96 pa strut knocking
i've been having a knocking in the front struts when i start to accelerate from a stop. i was told it is the strut plate. what is the strut plate and where is it. thanks
Old 08-19-2008, 02:31 PM
sarotara sarotara is offline
Re: 96 pa strut knocking
That's the part that connects the top of the strut to the vehicle body. Here is a good link with an explanation
http://www.monroe.com/tech_support/tec_struts.asp
Old 08-19-2008, 04:48 PM
does that mean i have to replace the entire strut or would just replacing the plate help get rid of the knocking.
Old 08-19-2008, 04:58 PM
jjmmcs jjmmcs is offline
Your best bet is to remove the strut and the strut plate (mount) and go from there. If the strut is shot replace it if not than just go with the mount.
Old 08-19-2008, 05:01 PM
I think you meant to suggest that he removes the front strut assembly, not the strut itself...
Old 08-19-2008, 05:03 PM
so the knocking means that i will not be able to reuse the plate or is it knocking because of something else?
Old 08-19-2008, 05:40 PM
yes that is what I meant but obviously they don't know much about the strut assembly so it is easier to put it in terms they can understand.
As for the strut mount being reusable if that is the problem than no.
There is a Rubber piece inside and when they go bad it is because that is broken or busting out of the mount.
Old 08-19-2008, 05:46 PM
appreciate the help. i will do what i can.
Old 08-19-2008, 06:24 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
And don't forget to have an alignment done after removing/installing these parts!
Old 08-25-2008, 11:11 PM
Greg5150 Greg5150 is offline
I had the same problem on my 1992 Park Ave and it turns out that the problem was a bad motor/trans mount. You may want to open the hood and hold the brake while you give it a little gas and see how much the engine moves.
Old 08-26-2008, 04:56 PM
Jrs3800 Jrs3800 is offline
Although thats a possibility, the Mounts on the 92 are different from the 96..
But just the same its worth checking..
Being a 96, it may be worthwhile to replace the Strut and strut mount with bearing plate... I had this same issue until I replaced the Strut mount and Bearing plate... No problems since
