Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 08-19-2008, 12:51 PM
ghalacsy ghalacsy is offline
95 ciera remote programming
hi, my mom has a 95 ciera and needs a new remote. i am looking for infoi on how to program it. thanks guy
Old 08-19-2008, 04:01 PM
Jrs3800 Jrs3800 is offline
Re: 95 ciera remote programming
Hi..
In the trunk there should be a lead for the keyless program wire in with the antenna wiring... This lead will be have to be grounded to send the Reciever into Program mode..
Once you do this the locks and most likely trunk release will cycle... You will then press a button on the remote, the locks will cycle again verifying that the remote has been learned... If you have another remote press any button and the locks will cycle when the second remote has been learned... After you have done this simply remove the ground from the connector..
If you have only one remote, remove the ground after that remote has been learned...
Good Luck and hope that helps..
Old 08-19-2008, 04:45 PM
appreciate it. i will try this weekend.
Old 08-19-2008, 10:00 PM
keilerstag keilerstag is offline
I have been wondering the same thing about my '93 cutlass ciera... is the same thing applicable to my car as is the 95?
Old 08-20-2008, 07:03 AM
iirc 1993 should be the same if you have keyless.. Both of these cars used the 104R Receiver and 104T Transmitter through 96 I believe...
